please help fuel injector problem on 95 z28
Old May 9, 2011 | 01:41 PM
detroit_903's Avatar
Default please help fuel injector problem on 95 z28
Okay so I been having a miss latley on my 95 z28 383 supercharged camaro. I replaced everything electrical -opti, wires,plugs,coil thinking that was the problem.. Still having a miss so we tested the fuel injectors they were getting the rite ohms so with the car running we decided to pull each fuel injector harness out testing each one to see if the car idles different worse or the same.. Thinking if it idles the same we found the problem or if it got worse that injector was working. Well anyways I pulled off one ---- nothing happen with the engine still was idling the same.. Plug that one back in tried another --- same thing, another same thing.. Tried 4 injectors and the motor did not do anything different no change in the idle or anything. What do u think the problem is??? Is there something I should like for -- harness or anything might be bad going to the injectors cause the motor should run really rough unpluging one harness rite???? PLEASE NEEED HELP
Old May 9, 2011 | 04:40 PM
LT1 4 the win's Avatar
Were all four of the pulled injectors on the same bank of the engine? How did the old plugs look? Did the plugs have black/white soot or smell like fuel/coolant? Id suggest a compression test of all the cylinders. Also you can put a vaccuum gauge on and watch as it changes when you pull each injector harness. This will allow you to see more of a change instead of just going be feel and ear.
