280 xfi dyno numbers
Old May 12, 2011 | 12:26 PM
nater36's Avatar
Default 280 xfi dyno numbers
mods are K&N intake system, pacesetter lt's, 3" ory, 3" exhaust, comp cams 280 xfi camshaft.
before camshaft car dynoed 285whp/321wtq... 11.9 A/F stock tune
after camshaft car dynoed 344whp/348wtq... 12.4 A/F.. fueling only tune no spark changes over stock
Old May 12, 2011 | 01:08 PM
mguidry629's Avatar
What's the rest of your valvetrain look like (springs, rockers, studs, pushrods, lifters)? Stock heads? If Auto, what stall you running?
Just curious.
I almost went with that cam for my 383, but I think I'm going to LE and get a custom grind.
Old May 12, 2011 | 02:52 PM
nater36's Avatar
its m6, bought the whole kit from comp. set redline at 6k, will still pull past that. No valve float issues with the new springs. stock studs, used scorpion rockers, no guideplates, stock heads
Old May 12, 2011 | 03:41 PM
mguidry629's Avatar
Have you been on camquest to look at the 280xfi cam dyno on there? Just curious if the curves/graphs are similar to yours. I know on camquest, it shows tons of torque on the bottom end and stays flat up to 4500 or so. That's what I really liked about the cam, but I don't know how accurate camquest is.
Old May 12, 2011 | 03:47 PM
nater36's Avatar
no havent been there... how do i load pics on here?
Old May 12, 2011 | 03:54 PM
nater36's Avatar
just checked out camquest, that thing isnt even close lol, forget that program
i can email you the dyno sheet since this wants a link just to put up a pic
Old May 12, 2011 | 08:56 PM
05HD's Avatar
Just host the picture on photobucket so you can post it here. It doesn't take any longer than making an email with an attachment and you can avoid having to email the picture to 40 different people who want to see it.
Old May 12, 2011 | 09:34 PM
nater36's Avatar
Old May 12, 2011 | 10:03 PM
TravisMcGill2000's Avatar
Great numbers.. Now put it on the track and lets see wat it traps
Old May 12, 2011 | 10:37 PM
gregrob's Avatar
Get a real rune on it. Numbers aren't bad though
Old May 13, 2011 | 05:09 AM
old93camaro's Avatar
i have that cam and le2 heads and make 415rwh so your on the right track...good numbers
Old May 13, 2011 | 11:11 AM
nater36's Avatar
LE1 heads up next for now
