what am i lookin at
Old May 19, 2011 | 11:46 PM
Silveraiderbc's Avatar
Default what am i lookin at
What kinda rwhp am I looking at, I am just finishing up a project that I got off of someone who ran outta money during his build Here it is
94 Z28
383 stroker fully forged
Cc 306 cam
Milled iron heads with intake and exhaust ported
Ported intake
Spec clutch
M6 3:42 gear
Lt's with OR/Y and cutout
Sorry I'm not real familiar with lt motors, first lt motor build and I'm not leaving anything out stock objectors and all, which leads me to some questions can someone give me an insight as to what an estimated hp and ET would be, and I do have the driver mod, not yryin to get in a ifs and buts kinda thread but the car isn't on the road yet so I'm just wanting to get sone insight if its not performing like it should when finished.. Thanks
Old May 19, 2011 | 11:49 PM
And also is there anything that the car sounds like it would need to help with the current mods.. Also I have it plumbed for a 150 shot
Old May 19, 2011 | 11:57 PM
LSWHO's Avatar
I'd be afraid to run stock injectors on that motor.
whytryz28's Avatar
Iron heads?
Old May 20, 2011 | 12:15 AM
heads off of a 96 SS impala, cast iron..
Old May 20, 2011 | 12:16 AM
what injectors would you suggest 32 lbs?
Old May 20, 2011 | 06:45 AM
Camaroking1996's Avatar
30 or 32 and get ported aluminum heads and you will get more horsepower
Old May 20, 2011 | 08:14 AM
I've got a set of stock heads that aren't ported but I decided to go with the cast because I just prefer them better with nitrous they're heavier and have less chance of lifting a head gasket
Old May 20, 2011 | 08:35 AM
quik95lt1's Avatar
wrong dude........all he will do is loose some weight..........and it would allow him to run more compression with pump gas.......as for iron lt1 head to aluminum the flow numbers are almost identical.......as for injectors id toss 36's in it.....
built correctly it will never happen.......with good gaskets and proper machining and a good fastener it will not lift a head.......i know people spraying in excess of 300hp and not lifting aluminum heads....
Old May 20, 2011 | 08:59 AM
[QUOTE=quik95lt1;14936589 never happen.......with good gaskets and proper machining and a good fastener it will not lift a head.......i know people spraying in excess of 300hp and not lifting aluminum heads....[/QUOTE]
yeah I understand that it can be made not to lift but I just like em better since I was using stock head bolts..
I'll prolly go with 36's like you said, thanks
Any one have any idea on rwhp, or some et's? Lol
