suspension and frame set up
http://www.hotrod.com/techarticles/n...ets/index.html
Would it be better to just get some rear coil overs instead of just a rear control bar?
The problem with that plan is that an LT1 motor that makes 500hp with no forced induction (supercharger or turbo) is going to be running a high compression. A supercharger makes additional power with boost, high compression and boost don't mix well. If you want to build a motor that handles boost well and makes a lot of power, it will need to be a low compression build and wont be very powerful without the supercharger/boost.
Like the others said, subframe connectors are a great investment for any fbody on any power level.
you going to need a 6 point at 11.49
an 8 point at 10.99
10 point at 9.99 or 135+mph
as for suspension the stock suspension is actually quite capable with a few little changes to add adjustibility.......get the torque arm relocation bracket for the trans and that will give you adjustibility on the torq arm height........get a set of lca relocation brackets and with that and the torq arm bracket you will be able to dial in your instant center........then grab a set of subframes to tie the car together and a set of drag bags for the rear and you will hook on a budget...........
I have weld in UMI 3 point SFCs kind of bolted up, but not welded in yet. They tuck up really well, fit great, and look pretty beefy.
Tunnel mount TAs are a good investment too if you have an auto, but if you have a stick I'd suggest the long TA and a relocation bracket. With a stick the TA will clunk and rattle really bad, but with the auto its alot less noticeable.
I would also suggest LCAs and relocation brackets. I didn't get the relocation brackets and had a little bit of wheel hop if the pavement was just right. I had poly ended non-adjustable LCAs. I think it made a big difference in how my car hooked, and the LCAs were a great addition to my adjustable UMI full length TA.
But last but not least tires and shocks play a big part too. But I have no pointers here, I was on stock shocks and cheap street tires the last few years. In a couple weeks I'll let you know how my new setup feels, but it was a HUGE change from where it was before.
an 8 point at 10.99
also ther are no solid SFC's
and again whats your goal for the car? mainly straight lines or do you want to carve corners too? that will determine what size & type of sway bars you want
Is there anything else i can do to that rear end to help it hold up or do i really have to start from scratch on it?
Regardless of what gears are in your 10 bolt, you're going to shred it. Even at 300 RWHP with slicks, you'll shred it.
If you expect to be around 500 RWHP and expect it to stick to the ground, regardless of whether it's going to be set up as a street car or drag car, these are the BARE MINIMUM, IMO:
12 bolt rear, 9" rear, or S60 rear. That 10 bolt will be blown to pieces.
SFC's (I have tubular bolt-ins, they're working great)
LCA's (I have non-adjustable tubulars)
Panhard bar (You'll need an adjustable if you lower your car)
Shock setup (I have stock springs with KYB AGX adjustable shocks)
Adjustable torque arm, tunnel mounted (I have UMI adjustable, tunnel mount is more rigid, and adjustability is needed for dialing it in).
Drag radials or Slicks.
I'm sitting right at 650 RWHP, and I've got a 12 bolt with M/T ET Street drag radials. Mine is set up for the street...and hooks like a badass.
Which companies make a solid Sub frame bolt on kit torque arm,LCA, panhard ect. I see a lot out there, but have never dealt with any of them.
. I appreciate all the advice.
