CSR waterpump failure
I can't complain too much about this thing finally failing. It's been in there for 7 years and over 50,000 miles.
What's really hard to believe is it still runs and pumps, just drips a little. I guess it's time to put the spare in that's been riding with the spare tire for 7 years.
your ewp has water getting into the "electrical motor part"....obviously not good. fortunately you have a spare and a ewp swap takes only minutes.
FWIW my Meziere has been on for 15 years now....WAY outlasting any OEM type WP. Spare meizere still sits in the trunk
...spare in the trunk will have me on the road again quickly
I returned my then 500 mile new AC Delco dealer installed WP (warrenty) and got a replacement one. It has been it it's unopened box since 99...as a door stop...works great
The second worked mint up until I parted the car out. The only issue I had was the drain on the battery was a bit much and the charging system on a stock pulley and no real stereo put a strain on everything.
If this LS1 ever gets one, it will be wired different. That is for sure.
