Fastest true lt1
Old Jun 14, 2011 | 02:09 PM
Puck's Avatar
Originally Posted by meaty97z
It is people like this these last to punks that make blogs like this turn to s$?t. The hole reason I asked of this is because there are alot of supposed lt1 that are not really lt1. Not to trough Tony under the Bus, but to me he is not the fastest lt1. The only thing that is lt1 on his car is the block, which to me means that it is not truly a lt1. It is basically a traditional small block chevy. So for all the people on here that won't talk trash about and Lt1 post then start reading other post that pertaint to other things like football that this jerk above loves talking about. All I had was a simple question.
One can counter argue the the only thing that DOES make an engine an LT1 is the block. IMO if its reverse cooled and a factory LT1 block, its an LT1. I don't care what ignition, intake, or heads are on it.
You wouldn't call an LS1 with a single plane an SBC, would you???
Old Jun 14, 2011 | 02:22 PM
quik95lt1's Avatar
very nicely said my friend..........
Old Jun 14, 2011 | 03:06 PM
draggin97s10's Avatar
i agree, perfectly said.
Old Jun 14, 2011 | 03:08 PM
LSWHO's Avatar
Wouldn't an eliminator car pretty much be the top?
Where's gizmo?
Old Jun 14, 2011 | 03:11 PM
quik95lt1's Avatar
Where's gizmo?
that car is a tad on the light side for this lol.......if i cant make it in even at stock 3500lbs he def wont lol
Old Jun 14, 2011 | 04:23 PM
LSWHO's Avatar
Op said nothing about weight, only the motor. Or did I miss something?
Old Jun 14, 2011 | 04:55 PM
meaty97z's Avatar
I did not say anything about weight. I will adjust weight as needed to accomplish the goal. I know for a fact that a car weighing above 3500lbs is capable of running in the low 9's.
Old Jun 14, 2011 | 05:11 PM
alexcoreas's Avatar
I just wasted 45 sec reading this entire thread. Now I know why people don't use the search button. Threads full of ****.
Old Jun 14, 2011 | 05:29 PM
LSWHO's Avatar
Lock the thread. We needed alexcoreas' stamp of approval for thread justification and we were just declined authorization.
Lock this thread!
Old Jun 14, 2011 | 05:31 PM
lemons12's Avatar
My 2000 lt1 runs bottom 7s@95....3500# rw... bolt ons. Just has ported milled stock 317s custom grind stock 226 cam stock kooks longtubes stock full bmr suspension, list goes on. Bone stock bolt ons.
Old Jun 14, 2011 | 05:43 PM
bore.me's Avatar
I think there are some turbo LT1's with mostly "LT1" parts that make 700hp, but if I'm wrong i'm sure i'll be corrected.
Old Jun 14, 2011 | 06:31 PM
  #32
Speed Density's Avatar
hashtagBMW
LOL. Mostly.
OP, Go find a stock eliminator car, then undo your panties.
Old Jun 14, 2011 | 08:29 PM
  #33
Ray@Nitrous Outlet
Guest
Posts: n/a
search for Jeff Gilbert ...and yes I know he used trickflow castings, but at one point he was still using stock castings
Old Jun 15, 2011 | 08:47 AM
  #34
mguidry629's Avatar
Wasn't trying to **** anyone off, just looking to add a bit of humor with an analogy to put this in perspective, but I guess it was funnier in my head.
I understand you were asking about an LT1 record, and I was trying to tell you that you're being too picky about the details and you'll never find the record your looking for without changing the parameters.
Did anyone really think they were going to open this thread and see a time posted in here?
BTW, I would have to agree that an LT1 block and reverse cooling should be enough to classify a motor as an LT1.
Old Jun 15, 2011 | 02:55 PM
  #35
LSWHO's Avatar
Originally Posted by mguidry629
an LT1 block should be enough to classify a motor as an LT1.
Corrected for my ever so important opinion.
Old Jun 20, 2011 | 07:51 AM
  #36
Tony Shepherd's Avatar
Wow, no hurt feelings here but I guess all the LS1 guys that went to the aftermarket LSX block that must make them non LS1 now eh? Those same guys go to sheet metal or Supervic intakes and MOZUS (sp?) heads. Guess you can't call them LS1 cars. lmao!
I still have a factory LT1 block, stock LT1 water pump housing, reverse flow cooling heads, stock LT1 timing cover...etc. To not call my car a LT1 is nuts.
Old Jun 20, 2011 | 08:14 AM
  #37
quik95lt1's Avatar
i got the same thing you do tony minus the solenoids bolted all ova the place lol...........not to call either one of our rockets an LT1 is nuts!!!
Old Jun 20, 2011 | 08:15 AM
  #38
quik95lt1's Avatar
sorry i got confused between this thread and some other rediclious thread i was reading..........my bad
Old Jun 20, 2011 | 08:20 AM
  #39
Formula383's Avatar
Yeah, so I guess I don't have an LT1 either and I still have an opti.
Sir, please back away from the crack pipe.
Old Jun 20, 2011 | 10:48 AM
  #40
speed_demon24's Avatar
Retardation is strong in this thread. And you guys wonder why LT1's have such a horrible name.
