how much gain from 3.73s?
Old Jun 21, 2011 | 08:04 PM
*02WS6TURK*'s Avatar
Originally Posted by nitrous2fast
Just get a set of 3.42's from some guy with a m6 that is doing a gear swap. you can get them pretty cheap.
They are stronger than 3.73's and will produce better mpg's, and give nearly the same performance.
I'm would be willing to part with my 3.42's for a good price. They are like new. Less then 25K on them.
Old Jun 21, 2011 | 08:31 PM
96TransAmboosted's Avatar
I use to have 2.73 gears and a 2800 stall would run 9.20 1/8 mile with a 2.10 60ft. Swapped to 3.73 and was running a 1.89 60ft and 8.80-8.99 depending on spin. This was all done on street tires that were pretty shot. The car loved the bottom end with those gears. I now run 4.11 in one car and 4.56 in another and both rocket out of the hole.
Old Jun 21, 2011 | 08:34 PM
lemons12's Avatar
Anyone who sees .2+, especially in the 1/8.. I would like to know DA calculations as well as ANY other changes to the car.
Old Jun 21, 2011 | 08:39 PM
lemons12's Avatar
Gears gain an awesome sotp feeling. The actual gains are minimal at best for autos.
The gear radio difference between 342s and 373s is so minimal the performance will be near identical..342s we cheaper, better mpg, stroker,etc.
Has been proven over and over that the et and mph difference is minimal at best between 323 342 and 373s.
I'm done arguing it.
Old Jun 21, 2011 | 08:48 PM
GREGG 97Z's Avatar
Originally Posted by camar0corey
I never understand all this MPG talk when it comes to gears. I went from 3.42s(m6) to 4.11s, no noticeable change in gas mileage. So what is the story, does the A4 just suck in regards to rear gear changes and mileage, or are people constantly bringing up an invalid point?
I went from 3.42 to 4:10s in mine too with no noticable difference in mpg. The m6 has such a low 6th gear though that it really doesn't matter which rear gear you have. With 4.10s at 70mph it only turns 2k rpm, before around 1500. After adding a cam 4.10s actually make 6th gear more usable, it doesn't bog at all. Not the same story for an a4.
Old Jun 21, 2011 | 09:12 PM
lemons12's Avatar
Without a doubt.
Old Jun 21, 2011 | 09:26 PM
97z28:.'s Avatar
DVS LT1 ...that's exactly what I wanted to hear...I can't wait to get those 3.73s in
Old Jun 21, 2011 | 10:00 PM
GM gears IMO are the only way to go. Ran a few different sets with great luck and no whine. Get a quality seal/bearing kit. No Chinese garbage.
Old Jun 21, 2011 | 10:19 PM
LSWHO's Avatar
Originally Posted by SS RRR
Because gas mileage really doesn't have a lot to do with rpm levels, but rather load on the engine. An auto has no physical connection to the engine. It takes more effort for that engine to do the same work a manual does. Pair that up with a loose converter and gears...
With a manual I went from 3.73's to 4.56's and get the same MPG.
I can easily prove/disprove the gas mileage and effect from gearing.
2 scans at a set cruising speed.
run one,
hold in 3rd gear 40mph.
scan AFGS
on same stretch of road same direction,
run two,
hold in 4th gear 40mph.
scan AFGS.
Calculate average AFGS for both runs.
If I wasn't lazy today and actually fixed my heater hose I could easily do this right now. Then we could once and for all prove one way or another gearing effect on load and gas mileage.
Old Jun 21, 2011 | 11:01 PM
ALH442's Avatar
you wont see much on the 60"with out a stall.When i bought my car it had 3.73 richmond gear i am switching to 3.42 to drop the rpm on the interstate some.might to have your rev limiter re set exp 2-3 shift.my 60" was 2.0~2.13 pretty consitant.
Old Jun 22, 2011 | 12:00 AM
gatorhead's Avatar
Just wanted to add that you would be needing a gear set for the 2 series carrier since you have the 2.73's
Old Jun 22, 2011 | 04:15 AM
  #32
boostedlt1's Avatar
just find an entire m6 rear end.
i bought an m6 3.42 rear end off of craigslist for $200, sold my stock 2.73 rear on craigslist for $125, so total with freshening up the 3.42 rear end was less than $100. definitely can't beat that with a stick.. with the rear end swap, aluminum driveshaft, and lca's i picked up .2-.3. but that could've easily been affect by many other things as well, like DA, etc...
Old Jun 22, 2011 | 07:13 AM
  #33
SS RRR's Avatar
Village Troll
Doing what you say might actually work to your advantage, but increase that test to different driving conditions, like every day drivers experience, with an entire tank of gas and you may be surprised. I already proved to myself with four different gear sets the mileage was not greatly affected by gear changes. The first gear set was between 4.10's gearing down to 3.73's and received the same 19/25mpg, and on a road trip even did 27mpg while the 4.10 were being used which was on a completely flat road in east Texas on a 90* day with the A/C on. With the current engine I went from 3.73's to 4.56's and got the same 12/17mpg. That's enough proof for me.
Old Jun 22, 2011 | 07:17 AM
  #34
Mystery Bird's Avatar
You wont be dissappointed. Make sure you get it tuned for the new gears as well.
Old Jun 22, 2011 | 10:42 AM
  #35
LSWHO's Avatar
My advantage? What do you mean? I agree with you, but I want to show technical data.
I believe mileage doesn't change much if at all, but NOT because load decreases. I believe it's from time spent at load decreasing with the gears. You don't accelerate as long therefore you don't use more fuel. My test would show that, but to do your way of testing would have too many variables to ever check.
Old Jun 22, 2011 | 11:41 AM
  #36
white ghost's Avatar
Thetruth is that it does consume more fuel. It takes fuel and air to make power. It takes power to spin the crank(rpms) so by the conclusion of fact the higher the rpms, the more fuel is consumed.
Old Jun 22, 2011 | 12:04 PM
  #37
SS RRR's Avatar
Village Troll
That's the point. In every day situations an engine is exposed to all kinds of load differences (ie one gear combo or situation may let the engine operate around torque peak for a longer period of time). There are advantages and disadvantages to different gear combos. Average them together and the outcome of fuel consumption is minimal.
Old Jun 22, 2011 | 12:29 PM
  #38
License2Ill's Avatar
Of course it does.
But I guess from 2.73's he does have a right to want more...they fuggin sux.
Now as one poster said.....variances between 3.23,3.42,and 3.73 might be minimal both in performance and consumption. But there is a difference.
I would probably skip 3.23 for a little more gusto in the 3.42s....3.73's seems like a lot but of course the final drive on the slush box should help depending on what its ratio is....anyone have a number?
Does GM put out 3.73 gears? You should be able to find GM 3.42s easy.
+1 for rumors of GM gears being the best. Do not run Zoom gears.
Old Jun 22, 2011 | 01:42 PM
  #39
nitrous2fast's Avatar
nearly all GM auto's have a .70 ratio in OD.
Old Jun 22, 2011 | 02:39 PM
  #40
95zsean's Avatar
Originally Posted by lemons12
I would do 342s before 373s. Better mpg, stronger, same et, cheaper.
I went from 3:42's to 3:73's and dont really like them. 60 mph it to slow for 6th and it revs to much for 5th. It does come out of the hole better but for the money I wish I'd have stayed with the 3:42"s. Just my 2 cents....
