Making a carburated LT1 fuel injected?
I've done a ton of searching. I have an LT1 that is carburated and wish to put it back the way it was meant to be (fuel injected). Does anyone make anything for this block so that it can run fuel injection or am I going to have to purchase all the stock components for it? Thanks.
Chris.
Chris.
depending on what year/car it is(since you didnt specify) youd need at least an intake, fuel rails, injectors, throttle body, map sensor, tp sensor, iac,mass airflow, PCM, wiring harness, some other random stuff...
