LT1 T-56 Drill Mod?
Do the LT1 clutch hydraulics need the drill mod? Or is this only for LS1 cars?
The LT1 clutch hose DOES have a restriction also. Whether it has the same effect as the restriction for the LS1 line is debatable. Likely not.
The restriction is on the MC end but not on the fitting surface, it is down in the hole about 1" deep or so, right where the bit ends in the pic. In fact I can just barely fit a 1/16th drill bit in this hole small hole. The 1/8" drill bit will fit in the upper portion of the fitting, but stops due to the restriction about 1" into the fitting. I then ran the 1/8" bit in to cut out the restriction.
Cant tell anything on the SC end do to the right angle fitting.
Doing this allowed me to shift harder without occasionally grinding gears. Do it and make sure you get the shavings out.
My MC and SC work great yet so I don't think I will replace them.
