Removing anti lock brakes
Al 95 Z28 tried to put the engine in from the top with the intake on today. Not happening
The motor most certainly DOES go in from the top... You just can't have anything on it except for the intake (ie, no front accessories, no headers) and the flywheel/clutch...
You also need a "happy hooker" or you need to fabone up. It is a plate that bolts to the top of the intake with an offset to the front and a swivel bar... Drops the motor right in, you just need to have the motor sideways to begin with... Drop it in and once the drivers side valve-cover clears you turn the motor while it is in the engine bay...
If you are talented, you can do it with only the fan shroud up top removed, ie the radiator and cowl and everything else can stay in place...
Here's an old pic for proof. This is 2005, pulling the 355 LT1 out to put in a 385 LT4 stroker.
Al 95 Z28, engine went right in sans the intake. The problem was the angle was so steep to clear the crank pulley and rear of the intake I could see a disaster, so I removed the intake.
Master to 3/16 inverted brake T to hard lines to each front hose to caliper.
Grab a handful of abs lulz and tug. Computer under dash above your left foot area, smash with a hammer.
BTW, I've removed the engine from the top and the bottom. Bottom is the easiest with least hassle.
