Stall Question????
Old Jul 8, 2011 | 11:45 PM
Big Bad Bud's Avatar
Default Stall Question????
See sig for current mods. I am looking at buying a Yank 3200 or an Edge. What stalls are suggested? I also have a buddy that says I will loose over drive if the stall is too high! BS?
Old Jul 9, 2011 | 01:02 AM
LSWHO's Avatar
Loose overdrive? "lose?"
You're friend needs an education on stalls.
3600+ on the stall.
Old Jul 9, 2011 | 01:07 AM
WhitePhoenix99's Avatar
You won't lose overdrive. I've had good luck with my Circle D converter, give them a call or check out their website.
http://www.circledspecialties.com/
Old Jul 9, 2011 | 06:45 AM
pillarpod's Avatar
I am a yank supporter, because that all i've used. They have great converters, and i'de go with a 3600 stall minimum
Old Jul 9, 2011 | 10:21 AM
96capricemgr's Avatar
Your friend is stuck a few DECADES in the past.
I would say 32-3600 with that cam for a street car.
Old Jul 9, 2011 | 10:25 AM
joelster's Avatar
SS4000 all the way. You have a cam. Your car makes peak hp well above 5k. The current crop of good converters for the 4L60 do not drive "loose" at all. You wouldn't be able to tell the difference between a 3200 and a 4000 converter if you are just puttering around town. They drive very much like stock when you are cruising. Drop the hammer and the difference will be noticeable. I've never heard of anyone getting a higher stall converter, and wishing they didn't go so high on the stall. I've heard of tons of people getting too small of a converter and later regretting it only a month or so later.
SS4000
Old Jul 9, 2011 | 11:20 AM
Ok Thanks guys and sorry about the "Loose" part! I meant "Lose"!
I'll go Yank 3600!
Old Jul 9, 2011 | 12:52 PM
IronOutlaw's Avatar
I loved my ss3600. Now you just have to find some traction. lol.
Old Jul 9, 2011 | 01:04 PM
SuperSport01's Avatar
Yank or Circle D. 3200-3600 stall. Make sure to add a trans cooler.
Old Jul 9, 2011 | 07:31 PM
lt1-xjs's Avatar
Originally Posted by big bad bud
ok thanks guys and sorry about the "loose" part! I meant "lose"!
I'll go yank 3600!
ss 3600.
Old Jul 9, 2011 | 08:15 PM
Dave357LT1's Avatar
I have a VIG 4400 and i love it. Drives normal and dosnt seem to generate as much heat as other converters
Old Jul 10, 2011 | 11:13 PM
Go On 3's Avatar
i dont have any input on other brands but im really happy with my yank ss3600, i think if you go any lower you will regret it
