cam swap tools
is there anything i should make sure to get as far as any larger sockets or deep sockets, wrenches or any other random tool that will make things easier?
3 jaw puller for crank pulley
Three 3" bolts for cam snout when first removing cam from block
Assortment of extensions including a wobble for the water pump bolt behind the power steering pump pulley.
1 gal. of coolant and 1 gal of water
Brake cleaner
either an install lube or 30wt oil when stabbing the new cam
clean rags
Keep the install as clean as possible. When the timing cover is off the oil pan is like a catch all so it's a good idea to cover the opening immediately upon removal of the timing cover. There is so much crap that needs to be scraped off the block it can easily end up in the bottom of the pan. IMO that is why so many cam installs have bearing issues.
Unless by some miracle the oil pan gasket may rip when taking the timing cover off. Putting a new gasket on is not necessary. Once the timing cover goes back on you can put a bead between the tears in the pan gasket, bolt up the pan and let it sit for around 12 hours before starting.
right now my list of things to get are:
rags
small torque wrench
big bucket
oil catch pan
3 bolts for cam
coolant
oil/filter
oil level sensor delete plug (anyone know what to use?)
i have a 4" puller. i assume thats big enough?
im trying to way over prepare for this haha
ss rrr brought me to another question... I plan on changing the pan gasket as well. i have a tubular k member and theres no way im separating the motor from the mounts. it took 3 hours to get the one bolt through the mount when i put it in (umi welded it crooked) can the pan gasket be changed without dropping the k member? the gasket i have is not stretchable
Brake cleaner
clean rags
rags
small torque wrench
big bucket
oil catch pan
3 bolts for cam
coolant
oil/filter
I'm not sure how you were able to take the timing cover off "with ease" when the oil pan was in place unless you or someone else ground the timing cover down...
I just thought of an experiment you could do to see if your theory is correct:
1. Pull your bottom lip out as far as you can
2. Let someone throw a bucket of dirt in your face
3. See just how clean your pie hole is afterwards
4. Post vid for proof
anyone have any info or links about changing a pan gasket with a tubular k member?
also, im assuming i can use the 4" 3 jaw puller for the crank pulley, hub, and gear? is re-installing as easy as tapping them back on? or do i Need an install tool for any of these? what size is the nut on the front of the crank?
