383 lt1
budget - heads maybe around 800
goals- well I dont know anything about LT1s but I see a lot of people talking about that is build. I just want to get the max hp and tq out of this built, well and win a race against another impala with a 383 in it lol
Apparently, the Charlotte/Concord NC area is the LT1 tuners mecca. http://advancedinduction.com/LTX/AiLTx200ccCompHead.php
If I were you, I'd wait until you have the budget to do your build the right way the first time.
its hard to beat these guys even if you go local....simply cus this is mostly all they do....you can get a set of loyds stage 2 for about 1400 total shipped and all...comes with springs,valves...etc...however i would agree you need to post your goals?hp?
I dunno... I would say get decent heads and it will make a world of difference. Save up and get a cam that complements the heads and even better things will happen.
You are planning to go about this wrong, will you be helped or are you going to persist in your mistake?
I know popular opinion is make the engine bigger, BUT IMO that is a mistake unless you have the budget to still do the topend right. To do a proper stroker with good new parts throughout you are going to be looking at $1800+ for the rotating assembly, $1000+ in machining/assembly, easily $3000+ in heads(ported GM)and valvetrain/gaskets. Still don't have the fuel system $500, CAI $100+, Exhaust $700+, tranny/TC $2300+, rearend work $800+, this is still not a complete list need tuning, going to find repairs(hoses/bushings/brakes etc.) to make along the way, still need suspension work.
IMO do all that other stuff first, then if you have a good solid $3000 left then look at heads and cam on the stock shortblock. If you still have $8000 left then consider a stroker
I know those numbers are scary, and some will argue they are high, maybe some are but I can also tell you most guys endup spending more than these numbers by the time you try a few things or make incremental changes as you want more power.
Yes my car is pump gas, it is a true street car, AC, ABS, power seats etc, always driven to and FROM the track, get high teens for mileage.
