mids vs longtubes
Old Jul 21, 2011 | 05:55 PM
mattj21's Avatar
Default mids vs longtubes
Torn between the pacesetter long tubes or the mid-length ones...car is a DD want more power and better sound but I dont know if its really worth it to get the long tubes over the mids..what do yall think?
Old Jul 21, 2011 | 05:57 PM
turfman514's Avatar
feel like changing your y pipe?
Old Jul 21, 2011 | 06:01 PM
bigj2717's Avatar
Longtubes hands down.
Old Jul 21, 2011 | 06:02 PM
mattj21's Avatar
Yea I am aware about the y-pipe..so if I get the longtubes what do I do about the y-pipe? Or do I just switch to an x?
Old Jul 21, 2011 | 06:04 PM
bigj2717's Avatar
If you look for longtubes on ebay most come with a off-road y-pipe. You can go with true duals if you want
Old Jul 21, 2011 | 06:12 PM
mattj21's Avatar
Right on, dont really wanna buy the ebay ones, but appreciate the help fellas.
Old Jul 21, 2011 | 07:11 PM
madhatter's Avatar
Long tubes, no question about it. I have had both. Unless you live in a smog **** city/state long tubes are the way to go.
Old Jul 22, 2011 | 07:21 AM
DAVE00's Avatar
If you ever plan on lowering the car, then don't go with LT's as they hang pretty low - even LPPs which tuck up the nicest. I am running the Eibach Pro kit and decided to go with RKsports (ASM copy) mids and custom y. They fit perfectly and I have the same primary size as most LTs at 1.75". After reviewing pictures on the net of cars with LTs and the ground clearance issues I went this route as the roads here in Houston aren't that great.
Old Jul 22, 2011 | 07:59 AM
quik95lt1's Avatar
long tubes................end of story
Old Jul 22, 2011 | 10:41 AM
96lt1m6's Avatar
Longtubes are great no doubt at all however you cannot dismiss the power made by
Mac mids.......
Depending on your mods, mids may just e better solution........
Old Jul 22, 2011 | 10:50 AM
katz_2003's Avatar
I have pacesetter lts and love em. I used to have Mac mids with my stock setup but these pacesetters look so much better. I am using the 3" off road y pipe with dmh cut out and love em. Do it right the first time and go LTs. U won't be disappointed
Old Jul 22, 2011 | 10:51 AM
Big Al's Avatar
My 95 has long tubes. They are almost up against the floor, passenger's side is a tad higher than the driver's side. They would be hard to hit if the car is at stock height. The problem is on the driver's side after the header there is not a lot of room to get to the rear with a true dual set up. Also, we in Tucson are held hostage by the smog ****'s. Something to think about if you are too.
Al 95 Z28 Frankenstein
Old Jul 22, 2011 | 10:52 AM
ZFreie's Avatar
My long tubes don't sit that low? I have slip fit pace setters and they sit no lower then the pinch welds really...I would have to bottom out my whole car to hit my manifolds. There are some pretty bad roads around in my area lol.
My Y pipe sits low cause its crooked...a tiny bit. and never finished coaxing it around with a hammer.. lol If it was straight I would have pretty good ground clearance.
Old Jul 22, 2011 | 04:39 PM
00FlowCamaro's Avatar
I never had problems scraping and I'm running Pacesetter LT's and ORY. Lowered with Pro Kit and Bilstein shocks. Only thing I would watch out for are speed bumps, of course you go slow over those anyway.
Old Jul 22, 2011 | 05:01 PM
lt1-xjs's Avatar
A good shortie or mid will produce as much as any longtube with the correct system. 3" collector required I run a shorty, 17 rwhp gain with X pipe system, long tube territory.
Old Jul 22, 2011 | 06:16 PM
trilkb's Avatar
longtubes...
Lowered cars dont launch good anyways
Old Jul 22, 2011 | 06:45 PM
AR15 guy's Avatar
My biggest complaint with long tubes is the y pipe hitting the frame under hard acceleration. It got really annoying on my DD 95 z28 and 02 Formula. My brothers 93z has pacesetter LT's with strano springs and he doesn't have to many problems with them scraping.
Old Jul 22, 2011 | 07:54 PM
SoxXpupPeT's Avatar
Mids like Mac Mids have extremely good ground clearance and make alotta power.
Old Jul 22, 2011 | 09:56 PM
AR15 guy's Avatar
I wish MAC made their mid-length headers without emissions. That is what has kept me from getting them.
