wont start
Old Jul 25, 2011 | 05:19 PM
95formulalt1350's Avatar
Default wont start
ok i got a 95 formulawith longtubes, magnaflow exhaust, msd ignition, k&n, egr delete, air delete, tb bypass,. the battery has a full charge but it wont turn over and the stater just makes a clciking sound im guessing the solenoid or starter but no sure and i have a high charging voltage any help thanks?
Old Jul 25, 2011 | 05:26 PM
draggin97s10's Avatar
well try rotating the engine over by hand first with a breaker bar and socket in the crank snot. if it rotates then i would guess starter. Go from there.
Old Jul 25, 2011 | 09:05 PM
puddingmmmmmmmm's Avatar
Sounds like the starter.
Old Jul 25, 2011 | 09:07 PM
bigj2717's Avatar
Yeah for sure sounds like the starter. You can always pull it out and take it to autozone and have them test if for free to make sure
Old Jul 26, 2011 | 01:13 AM
Big Al's Avatar
Sounds like a dirty battery cable connection. http://shbox.com/1/starter_charging_95.jpg will show you the circuit. You can test the various connections with a 99 cent test lamp.
Al 95 Z28
Old Jul 26, 2011 | 01:33 AM
TSAEB's Avatar
Take ur starter bat and alt to get checked. Y guess if u can check it for free.
