The Oil Leak Mystery
So I'm trying to figure out this oil leak, I don't think its the o-ring from the water pump because when i replaced the pump I made sure to put back in the right away as well as putting the bands on. What else could it be? got some pics, I just haven't had a chance to dig in the engine to look.
Any suggestions where I start? where are the most common leaks?
I have a 97 Trans am
![](http://i100.photobucket.com/albums/m17/johnnythehmc666/IMG_20110725_143219.jpg)
![](http://i100.photobucket.com/albums/m17/johnnythehmc666/IMG_20110725_143208.jpg)
![](http://i100.photobucket.com/albums/m17/johnnythehmc666/IMG_20110725_143152.jpg)
![](http://i100.photobucket.com/albums/m17/johnnythehmc666/IMG_20110725_143142.jpg)
![](http://i100.photobucket.com/albums/m17/johnnythehmc666/IMG_20110725_143135.jpg)
wipe it all down, then crank it and see if it leaks enough to spot it. also don't forget the front of the intake, as a source. they also make dye kits with uv lights that could help locate it.
