wiring
Old Jul 27, 2011 | 08:22 AM
ohhyea102's Avatar
Default wiring
hey guys ive got a friend that has a 97 z28 and the engine wiring harness went up in smoke. i think it was laying on the headers but what do guys think would be the easiest and cheapest way to fix it?
Old Jul 27, 2011 | 08:41 AM
shbox's Avatar
Buy some wire, splice out the damage, solder and heatshrink.
Old Jul 27, 2011 | 08:42 AM
RamAir95TA's Avatar
Depends on the damage and to which wires. But like Rob mentioned that's the best route if it isn't completely toasted.
Old Jul 27, 2011 | 11:37 AM
Big Al's Avatar
I'll add: Buy some good wire, the crap they sell in auto parts stores is exactly that. Better off buying an old harness off any car or truck and cutting out the wire you need. Factory wire is much more flexible and tends to have better insulation. Soldering is the best way to connect the wires but be careful with the heat shrink. It needs to be long enough to keep the wires from flexing near the joint or the wires will break. The solder makes the joint rigid. Use a quality soldering iron, like a Weller. Cheap irons are good if you are very good at soldering, otherwise they are only good for wood burning.
Al 95 Z28
Old Jul 27, 2011 | 05:31 PM
ohhyea102's Avatar
thanks guys i didnt even think of that. i just took a quick glance at it and it look like it was just in one spot. it caught fire on the passenger side. i think it was the harness that the passenger injectors are on. ill try that though its a great idea.
thanks derreck
Old Jul 27, 2011 | 09:37 PM
waltsfastz's Avatar
Not sure about now, but back in 2000 I replaced the engine harness on my 96 and it was roughly 300 from the dealer, However I tried to get one for a 2000 Monte Carlo that came in the shop today and it had already been discontinued. Junkyard had one for this car for 150 bucks.
Old Jul 27, 2011 | 10:20 PM
Lawhead's Avatar
I have a harness I would get rid of cheap would just need to add all your Tranny stuff to it because it was used on a TH400 car PM if your interested
Old Jul 28, 2011 | 06:03 AM
ohhyea102's Avatar
thanks for letting me know but i am going to try and splice the wires first. going to work on it this weekend. ill let you know though.
thanks derreck
 Michael S. Palmer
