How to install crank timing gear at home??
I bought a rebuilt shortblock, and there is no crank timing gear installed. I have a new Cloyes 3039 timing set and need to install the crank gear at home.
Whats the best way to go about doing this?
Do I install the gear over the key, or install the gear and tap in the key?
If your key is not already in, i would go ahead and put that in first. Then just tap the gear over the key.. It does not take a lot of force so don't go ape **** on it.
