is bypassing the knock sensor safe.
Old Jul 27, 2011 | 11:58 PM
93z28ltfun's Avatar
Default is bypassing the knock sensor safe.
im running a 93 z28 ( 93 cars have ecm ) thats getting some timing knocked off ny the knock sensor. about 5 degrees. im thinking about doing the 3.9k resistor in line to bypass it and was wondering how safe it is. i only run 93 octane and i more or less just want one or two good runs at the track. its obd1 so i cant use a lt4 km
Old Jul 28, 2011 | 12:02 AM
gregrob's Avatar
Lol...
Nothing is "safe". With that attitude you should put it back to stock.
Disabling the knock hardware instead of properly tuning it and eliminating false knock is retarded.
And who said you cant use an LT4 KM on OBD I....? You can
lt1-xjs's Avatar
Originally Posted by 93z28ltfun
im running a 93 z28 thats getting some timing knocked off ny the knock sensor. about 5 degrees. im thinking about doing the 3.9k resistor in line to bypass it and was wondering how safe it is. i only run 93 octane and i more or less just want one or two good runs at the track. its obd1 so i cant use a lt4 km
It can be desensitized through a tune, I used Alvin at pcmforless.
Old Jul 28, 2011 | 01:16 AM
93z28ltfun's Avatar
Originally Posted by gregrob
Lol...
obd1 one uses an ecm and in which the knock module is soldered inside it. the lt4 wasnt even used in 93 in the vettes yet. there is alot of differences between 93 lt1's and 94-up. ecm, speed desity, 22lbs injectors ect. now if there is some secret that you know about them im all ears.
Old Jul 28, 2011 | 03:13 AM
gregrob's Avatar
You have your facts mixed up
Old Jul 28, 2011 | 06:14 AM
RamAir95TA's Avatar
You're wrong, period. There is NO provision on the 93 PCM for the knock module.
Old Jul 28, 2011 | 06:59 AM
DAVE00's Avatar
WRONGGGGGG. Not in a 93' man.
Also, sometimes you simply cannot tune out all false knock and you just have to bite the bullett and tune it out or in his case do the resistor mod.
Old Jul 28, 2011 | 08:18 AM
quik95lt1's Avatar
i ran no knock sensor on my 355 nor my current 385.........make sure you're tunes right and you wont have any issues..............
Old Jul 28, 2011 | 02:31 PM
LSWHO's Avatar
Desensitizing doesn't work as well as the lt4 km does.
Tune it out like quik said.
Old Jul 28, 2011 | 03:03 PM
gregrob's Avatar
No Im not, period. He said OBD I can't use an LT4 knock module. Which is not correct.
I know full well the 93 PCM is different and can't use the LT4 KM, but that's not what he said.
Don't want someone reading later on thinking you can't use an LT4 KM with OBD I because you can. Just not a 93
Old Jul 28, 2011 | 03:25 PM
DAVE00's Avatar
Splitting hairs!!! Making a general statement does not solve or answer his question, when you know full well (as he stated it) he has a 93' PCM.
Old Jul 28, 2011 | 03:28 PM
gregrob's Avatar
I like hairy splits
Old Jul 28, 2011 | 04:12 PM
93z28ltfun's Avatar
ok well i guess ill give it a shot. if i does work really good maybe ill wire up a toggle switch so i can use it when driving normal and bypass it when racing. ill let you guy know what happens.
Old Jul 28, 2011 | 04:19 PM
Puck's Avatar
You can easily desensitize the stock knock module to work just as well or better then the LT4 KM.
I have a 93 and desensitized it myself through the tune, and my tuner said I did it perfectly. The knock sensor still functioned, and didn't pick up false knock.
Old Jul 28, 2011 | 04:36 PM
nitrous2fast's Avatar
I quicken the recovery rate as well.
Old Jul 28, 2011 | 05:05 PM
LSWHO's Avatar
Prior to getting my own tuning setup, my mail tuner had "desensitized" my ks.
It may help on some or most, but I am living proof that not all of them get it right.
Old Jul 28, 2011 | 05:11 PM
jessebuickguy's Avatar
I'm wondering if there are any accounts of people destroying their engines from bypassing the knock sensor.
Old Jul 28, 2011 | 05:16 PM
speed_demon24's Avatar
Can you imagine all the people with solid rollers or older cars? They must be living in fear constantly with no knock sensors!
Old Jul 28, 2011 | 06:01 PM
Puck's Avatar
It is not really something that can be done in one try remotely.
You have to gradually get more and more aggressive until you just barely remove the false knock. Too much desensitizing and your KS won't pick up REAL knock, so just like with fueling and timing a mail order tuner will be conservative.
Old Jul 28, 2011 | 06:16 PM
Ohh the HORROR. I have noticed how sensitive people are to this issue. I am truly debating if the benefits of the knock sensor outweigh its annoyance.
