Roomie's LT1 Fiasco - What's Wrong?
Old 07-29-2011 | 08:47 PM
Jpack's Avatar
It was assumed that vented opti was the whole deal, not an opti cap. If just the cap, would still work.... if it was an 93 opti it physically will not fill the 96 timing cover hole..... it would be pretty obvious something was wrong when installing it let alone trying to bolt it down.
Old 07-29-2011 | 08:49 PM
defaultexistence's Avatar
Originally Posted by Jpack
no you missed the opti was a vented conversion on the old 93 and put onto the 96 engine.
Originally Posted by Ocala93TA
I was thinking the same after reading the post theres no way a 93 will work on a 96 .
Originally Posted by nitrous2fast
A 93's timing cover and all of the opti stuff could be switch over but the dowl pin would have to be swapped also. By opti stuff I mean timing set and other components required.
Quoteing y'all quoting me ... OP?
Old 07-30-2011 | 12:00 AM
klawittera's Avatar
I'm more curious as to how it got wired up. 96s came with MAF, sequential Fuel Injection, and a crank position sensor, whereas a 93 operates under speed-density and batch FI and thats it. thats just the basics. There has to be somehting wrong in the wiring.
Old 07-30-2011 | 12:22 AM
qc97z's Avatar
^This.
Old 07-30-2011 | 05:51 AM
ZGOBYBY's Avatar
Regarding the cam pin, Porter said he ground this down to fit, and the timing cover was switched. He claims he covered that issue. The intake from the '93 (which I think inside houses the sensors that speed density utilizes) was placed on the '93, the MAF isn't being used. PCM is being used from the '93 as well.
Old 07-30-2011 | 05:52 AM
ZGOBYBY's Avatar
I mean the '93 intake was placed on the '96 motor. Sorry for the confusion.
Old 07-30-2011 | 09:03 AM
camar0corey's Avatar
Running the 93 PCM, the mechanical motor has no idea it isn't utilizing the CPS or MAF..... Come on everyone lets not get hung up on this, there is no problem running a OBD-II year range motor in a OBD-I range car......
I put a 96 Impala motor in a 94 Formula, no wiring problems.
Old 07-30-2011 | 01:47 PM
ZGOBYBY's Avatar
Agreed, the actual motor doesn't have a clue.
Old 07-30-2011 | 04:25 PM
nitrous2fast's Avatar
What about plugs? You said wires were on correctly. Even if they are.... with bad plugs nothing is going to run right.
Old 07-30-2011 | 11:57 PM
z_speedfreak's Avatar
have you verified spark at each plug? didn't see it mentioned and its the easiest place to start if you haven't already. also triple check the spark plug wire routing
also what did you do about the fuel rail cross over since '93 intakes don't have one?
Old 07-31-2011 | 12:29 AM
Were the injectors from the 93 used or the other motor?
Old 07-31-2011 | 05:06 PM
  #32
ZGOBYBY's Avatar
The fuel rail and injectors were used from the '93 as well, and the plugs were new obviously.
Quick Reply: Roomie's LT1 Fiasco - What's Wrong?
