Craig Moates is the MAN!!!!
Old Aug 1, 2011 | 07:10 AM
DAVE00's Avatar
Default Craig Moates is the MAN!!!!
Guys,
Just wanted to share a quick customer service story with you about Craig Moates and his shop. Last week I sent them an email on their site asking for help with my ALDL cable as I have been having "Data Err" messages alot in Datamaster and since I have pretty much ruled everything out I figured the USB convertor or cable might have an issue. Craig, sent me an email with in 2 hours asking me what style I had, so I sent him some pictures as I was not completely sure as I bought this second hand several years ago and not directly from Craig. Craig then got right back to me and told me he was not sure if the convertor and cable was his, but that he would RMA it anyway and told me to keep my old one as a spare. He then Priority Mailed me a brand new ALDU1 and CABL1 setup FREE of CHARGE and got here in 2 days!!!!! Now this has to be some of the most incredible customer service I have ever seen. I havn't had a chance to try out the cable yet as I was stuck moving my In-Laws all weekend, but I can't thank Craig enough!!!! Go with this guy (if you haven't already) as he will really stand behind his products and take care of you for a long time.
Old Aug 1, 2011 | 10:40 PM
fex77k's Avatar
I picked up one of his obd1 cables last month, quality piece.
Old Aug 2, 2011 | 07:47 AM
garage_queen's Avatar
Moates is the only one I'll deal with for my tuning needs. Top notch and has been for many many years.
Old Aug 2, 2011 | 02:52 PM
Speed Density's Avatar
hashtagBMW
He was really helpful when I had my APU1 and the return policy is mint.
Old Aug 2, 2011 | 04:09 PM
spudnick3119's Avatar
I'm really interested to see if a new cable fixed your issues. I get the same Data ERR messages in Datamaster as well as trouble codes that Datamaster picks up for exactly one data entry then disappear. Also get (false?) knock readings, but they might be related to the exhaust banging on the k-member and frame a little bit.
Old Aug 3, 2011 | 06:34 AM
DAVE00's Avatar
The cable works perfectly, however it didn't fix my issue. I switched PCM's last night to a BU I have and still no luck. I'm going to be swapping out the ground strap on the Driverside head to the body as it looks pretty corroded and see if that helps. If not then I'll learn to ignore it as the car is running fine.
Old Aug 3, 2011 | 08:31 AM
96lt4c4's Avatar
Craigs stuff is all I use.
Old Aug 3, 2011 | 11:08 AM
fex77k's Avatar
Get a BBC ground strap off summit. Its relatively cheap and well built.
