missfire!!!!
#1 195
#2 165
#3 165
#4 195
#5 190
#6 190
#7 190
#8 190
im out of ideas plz help
Is it stock? or what are your mods? Might as well make a signature and tell us a little bit about the car.
Welcome to the site...
Don't really know what to tell you on the misfire problem. Kind of hard to diagnose over the internet. Maybe a better explanation will get you some more replies. Is it subtle or real noticable? does it buck or stutter? or is like hitting a rev limiter? or does it feel like you lose one cylinder?
And you're saying no problems exist under 5000 rpm, correct?
How are your plug wires ran? Anywhere near the headers? And you triple checked the wires are in the right order on the opti...
Does it do it when it's cold too or only after it is hot?
Fuel pressure is......
I don't think it is (but it is possible) but you could probably look up stall wall and see if that pertains to you or not.
i will be checking the fuel pressure tonight.
what is a stall wall i have never heard of that
the most confusing thing is that it did not do this before it came apart for head gasket...
1997 trans am- 2800 stall with built trans,cam and bigger stall waiting for install, headers, cold air, alt relocation, no heat, no ac, no powersteering, gutted! TTm wheels
theres my sig bud. if that helps
most people said stalls above 3000 rpm, and obd2 cars will not have stall wall issues. but it did the same thing when i had my 4000 fuddle stall in there.
idle/start: 36psi
normal driving/ 1750rpm: 38psi
wot/ all the way to 5500rpm threw missfire: 42 to 44psi
throttle bump/ throttle tap from 1000 to 1500 rpm jump: 42 to 44 psi
not sure if thats good or not but thats was it is from the port on the fuel rail
I kinda like the comment about the rotor screws backing out, but it would be anytime the rotor gets under high rpm not just post 5k.
Have you made sure all your grounds are good under the coil mounting bracket?
BTW your fuel pressure should be 43 at idle with line off regulator. Also check the regulator vac line.If it has gas in it, then it is bad.
