leaking water?
Old Aug 1, 2011 | 05:19 PM
Camaro_ZL2's Avatar
Default leaking water?
ok so today i finally got a new battery for my car since its leaving to the body shop i turn it on and seems everything is good until it starts leaking water but couldnt tell til i go near the battery and felt it leaking which seems to becoming from on top of the harmonic balancer........and it sprays out.... kinda like a hose is ripped or a hole in it but i see nothing wrong could it be the water pump?
Old Aug 1, 2011 | 05:22 PM
mguidry629's Avatar
There's a weep hole on the bottom of the water pump that will drip water if the seal goes bad, letting you know that you need a new water pump or at least a new seal. This hole is located directly on top of the balancer and opti.
Old Aug 1, 2011 | 05:24 PM
Camaro_ZL2's Avatar
thanks man doesnt seem like the water pump is bad cuz its coming out with pressure but i guess ill have to wait to fix that until it comes back from the bodyshop
Old Aug 1, 2011 | 05:32 PM
Camaro_ZL2's Avatar
and right now i checked the car is off and aint leaking so im guessing it is the water pump seal
