comp xfi 292 spring recomendation?
Old Jul 31, 2011 | 05:57 PM
Hit em Up's Avatar
Default comp xfi 292 spring recomendation?
Need to place order 2moro for springs.What springs will work for this and leave some on the table for very near cam upgrade.I've searched and all I find is what not to use and that comps recommendation is far off. BTW the heads are lt4 and whats recomended install height? Thx for the help..part numbers if possible.
Old Jul 31, 2011 | 06:50 PM
96lt1m6's Avatar
What does the cam card suggest for springs?
A call to comp is what I would do.
Old Jul 31, 2011 | 07:58 PM
slownova73's Avatar
It suggest the 918 beehives, but id get some alot stronger, i still had some valve float with mine and the beehives.
Old Jul 31, 2011 | 08:35 PM
Hit em Up's Avatar
Ok thanx for the advice,which springs did u end up switching to?
Old Jul 31, 2011 | 09:38 PM
joelster's Avatar
I run that cam 242/248, .584"/.579" with 918 beehives and have ZERO issues. Just make sure to get the install height correct. I had to order locks that moved the retainer up .050" to get the install height perfect. I run TFS 195 heads.
Old Jul 31, 2011 | 09:52 PM
Hit em Up's Avatar
Thanks for the heads up,Im just thinking of going with a spring slightly over what's needed so when I upgrade cams very soon I will be ok.Where do you shift your car?
Old Aug 1, 2011 | 06:15 AM
joelster's Avatar
Originally Posted by hit em up
.where do you shift your car?
68-6900
Old Aug 1, 2011 | 08:35 AM
speed_demon24's Avatar
Are you still running LT4 valves?
Old Aug 1, 2011 | 09:04 AM
Hit em Up's Avatar
Yes..
Old Aug 1, 2011 | 06:31 PM
trilkb's Avatar
need to know what lift youll be running, what rocker arms, what lifters, what pushrods.
