Hitting rev limiter at WOT then shifting
Thanks!
...post #2 would be my first concern as well. Bouncing off the rev limiter prior to shifting usually means the trans is going south.
1) if this happens in first gear more than 2nd and beyond. Have no fear, the stock tachometer is a bit slow, thus when you are in 1st at WOT the gauge can't ascend as fast as the motor is revving.
2) if this is all gears, you have some sort of tranny issue but I would verify first by checking the PCM for codes and probably doing a fluid/filter change might help your case also.
3) shifting at redline after bouncing the rev limit isn't awful but it isn't something I would make a habit of either. Besides the lt1 really stops making power after 5800.
Back when my 93 lt1 vette was bolt ons I found 1.6 rrs new springs and pushrods really helped over 5000 rpm. I did march pullies at the same time and my mph went from 106 to 111. Most because I was hanging on to 4th longer which I couldnt do before because the motor felt like it was strangled after 5k rpm (had 4.09s in the back).
Not that it helps the op I just felt like sharing that?
To the op: are you feeling the car jerk and buck when it hits the limited or are you seeing it on the tach? Could be inaccurate tach as mentioned by others
