Bad Clutch Vibrations After Install
What would cause the clutch pedal to vibrate? The vibrations also can be felt in the shifter, as well as a slight ticking sound coming from the clutch area.
Would a unaligned disk cause this?
The flywheel was resurfaced during the clutch install.
If you were able to install the trans without much difficulty then the clutch disc had to have been in alignment. You would never get the input shaft to go in if it wasn't. Once you install the trans depress the pedal and release the pressure plate that allows the clutch to align itself.
I used a telescoping transmission jack and did all of the work on a lift, so I'm pretty sure the input shaft is fine.
I made the mistake of not knowing at the time it had to sit right up against the flywheel because the torque wrench would say its good before it was fully seated and there was space between the PP and flywheel, which caused major vibration and had to be fixed immediately. Throw out bearing was toast from just a little bit of driving with the vibration.
Could very possibly be your problem..
I'm not sure if that means anything though.
I changed from a pilot bearing to a pilot bushing though - not sure if that would cause an issue.
Did it feel nice and smooth when you test turned it?
I had a lot of problems with TB and found out mine was recalled(the kit I purchased). Company ended up giving me an entire new clutch kit because of it.
My guts telling me the vibrations are coming from something being bent or warped. Maybe the hub of your friction disk accidently got a little bent up from taking the tranny in and out so many times? Not really sure though.
Counted_Out, your car is a freaking mystery.
In this one, you can see the bolt/pressure plate sits flat against the flywheel
In this one, you can see that there is a gap.
I checked the torque and they both seem to be at 22lbs. Is it supposed to be like this?
