Help removing egr valve
Old Aug 9, 2011 | 01:01 AM
323steel36's Avatar
Default Help removing egr valve
I need help it seems the egr valve are a pita to deal with on these lt1s especially the 93s. I checked to see if my egr valve was working with a pump and it was not holding suction/pressure. I am getting ready to smog the car so I need to find a way to take this crap off and put a new one on.
Just out of curiosity before I try taking it off, is there any other way to test that it really works?
Any ideas on how to remove these?
Old Aug 9, 2011 | 05:42 AM
RamAir95TA's Avatar
It's just two bolts. You have to reach back there and feel around and work blindly, but it will come off just fine.
Are you getting any codes to suggest that the EGR isn't working?
Old Aug 9, 2011 | 12:38 PM
323steel36's Avatar
Well there is no engine light on, is there a way to check for a code on my 93 to see if the engine light is on? Do i use the two wire way to connect it and see what code it gives me?
Old Aug 9, 2011 | 12:39 PM
RamAir95TA's Avatar
Boom.
Old Aug 9, 2011 | 12:46 PM
323steel36's Avatar
Ok when I push the egr valve diaphram the engine wants to turn off, but doesnt? Is this good or bad.
Old Aug 9, 2011 | 12:49 PM
RamAir95TA's Avatar
That's fine - that's what is supposed to happen. Doesn't sound like you have a problem with the valve itself.
This page will help you further:
http://shbox.com/1/4th_gen_EGR.html
Old Aug 9, 2011 | 01:03 PM
323steel36's Avatar
Boom.
OK so I got code 12, which in my hanes book seems to be nothing?
If the egr is not working does it show as a code?
Old Aug 9, 2011 | 01:23 PM
RamAir95TA's Avatar
Read the image again concerning code 12.
If you have no SES lights and the engine stumbles when you depress the EGR valve all signs point to the system working properly.
Old Aug 9, 2011 | 02:51 PM
shbox's Avatar
If the valve won't hold vacuum, it will never work. Manually pressing on the valve, resulting in engine RPM change tells you the ports are not clogged up. Still, if the valve will not open with vacuum, you need a new one. Whether that is something they can catch on a smog test, IDK.
Old Aug 12, 2011 | 12:57 AM
323steel36's Avatar
It sucks thats so hard to take out especially on the 93 dam.
