24X harness repin?
1994 4L60E
Not desirable. Different than 1995. Does not have provision in the valve body for TCC solenoid.
1995 4L60E
Provision to receive 1996-newer wire harness and solenoids. One person has suggested nothing but success and thousand(s) of miles after a simple harness and solenoid swap. Another has expressed failure and insists that the valve body, pump, solenoids, and internal harness must all be swapped.
With conflicting information, I would suggest using a 1996-newer transmission or working with a trusted transmission builder.
1994 4L60E
1995 4L60E
96-97 DIY kits do not include a new DLC because no changes are required at the DLC
Each DIY kit has its own part number.
Here's some pics to help..I posted them in another thread earlier..
Flip the Connector over and with a pic carefully remove the retaining clip..depress the little tab in the slot on each side of them and slightly pull..
To remove the Pin just push it forward a hair, then with your finger nail pull up on the tab..then pull the pin through the other side..
Then when you have the other one out just push it through and it locks in place. When you are finished put everything back together and you are done..
O.K thanks I must have got the 94-95 DIY kit. I am going to start working on it today just need to get some tape and electrical cleaner.
