Suspension mod
Old Aug 13, 2011 | 12:48 PM
94gt8er's Avatar
Default Suspension mod
I was wonder what some good suspension mods were?
My car right now has LT's y pipe cat back 373s.
94a4lt1
Old Aug 13, 2011 | 12:51 PM
transbird95's Avatar
An adjustable torque arm and lower control arms with relocation brackets are a good start. Subframe connectors too. Might want to look into some shocks depending on what you wanna do with the car also I have QA1 adjustable ones in the rear of mine. If the car is lowerd you will need an adjustable panhard bar too.
Old Aug 13, 2011 | 01:05 PM
94gt8er's Avatar
Ok Thanks.so should I go with all adjustable parts, and is there any brands to look for
Old Aug 13, 2011 | 01:07 PM
Zlow28's Avatar
Couldnt have said it better myself. Shocks will make a hell of a difference on riding, but theyre usually a little pricey. Id get SFC first, then LCAs w/relocation brackets, and finally and adjustable PHB. Also if you can find a cheap strut tower brace, get one. Some people say they dont feel a difference, but I felt the car turn a slightly better.
Old Aug 13, 2011 | 01:30 PM
RamAir95TA's Avatar
The single best suspension modification you can add is a stickier tire, hands down. Most people don't consider it a suspension modification, but you can add all the LCAs, torque arms, subframes, etc. in the world but it won't do you any good if you're running on plain jane street tires.
Old Aug 13, 2011 | 02:04 PM
96TransAmboosted's Avatar
True tires are a great choice but Sfc are much better IMO and could net you .3 and Lca are great as well. But you don't need am ajustable panhard rod.
Old Aug 13, 2011 | 02:53 PM
You gained 3 tenths from just installing sub-frame connectors? Just curious.
Old Aug 13, 2011 | 04:26 PM
RamAir95TA's Avatar
There is no way SFCs alone can provide you with a .3 gain, neither will LCAs, or the two of them together.
Old Aug 13, 2011 | 04:49 PM
Tbird232ci's Avatar
Before suggesting parts, what do you want to do with the car?
Old Aug 13, 2011 | 06:02 PM
tbag_skywalker's Avatar
Weld-in subframe connectors, control arms, and relo brackets are a good place to start. If you plan on lowering the car, you'll need an adjustable panhard bar. It won't help your launch, but it will allow you to recenter the rear end under the car.
Personally, I wouldn't spend big money on a torque arm unless you're gonna be doing some serious building and running very fast times. I run a stock torque arm, all I did was swap out the old rubber mount for a polyurethane one and I'm very happy with how my car launches. Same thing with shocks like QA1's, yes they help and they're a great product, but you won't need them unless you're going to be very fast and competitive.
Also, as nice as subframe connectors are, there's no chance in hell you'll gain 0.3 in the quarter. Maybe 0.03.
Do what RamAir95TA said and get some good tires, then start with the small stuff like relo brackets, lca's, and subframes.
Old Aug 13, 2011 | 08:04 PM
Yes my car gained .3 when I added SFC to my head and cam car. I already had LCA on the car. Now my t tops don't pop out either anymore.
Old Aug 13, 2011 | 08:14 PM
RamAir95TA's Avatar
This is hilarious.
Old Aug 13, 2011 | 09:46 PM
lifeisgood's Avatar
That's a new one on me.
The only cars I've seen POP t tops out are sub 10sec cars, and there is no way ur transferring that much energy to the rear to net 3 tenths. I'm thinking u may have learn to drive a lil better that time around
Old Aug 13, 2011 | 10:09 PM
Car put out 520 on a 175 shot. I broke many stock parts along the way. And 2 diffrent t tops
Old Aug 13, 2011 | 10:23 PM
lifeisgood's Avatar
my 02 ss put 540 and 590 through an auto, with no cage and no sfc nothing but the stock everything and a turbo kit.
your car a manual? just kinda weird.
Old Aug 14, 2011 | 11:38 AM
Car had a turbo 350 with trans brake and 3800 stall, had a moser 12bolt with 3.90 gears. I will say I gained a solid. 2-.3 from the SFC give or take a tenth. I could tell a huge diffrence in the chassis after the install just driving around town. My buddy hawk gained .2 from his connectors as well. He even said that his car came out of the hole much better with the boxed connectors vs the tube he had prior on a diffrent car.
Old Aug 14, 2011 | 12:47 PM
SS MPSTR's Avatar
Car may have gained .3, but it was not attributable to the SFC...
Old Aug 14, 2011 | 03:14 PM
lifeisgood's Avatar
I'll give u that the cars do feel a million times different driving them.....but if that's what u think did it, its pointless to argue.
Either way they're a good mod. I just don't agree with the et drop
Old Aug 14, 2011 | 10:44 PM
94gt8er's Avatar
is Spohn a good brand
Old Aug 15, 2011 | 06:16 AM
RamAir95TA's Avatar
For what?
I used to use Spohn for everything, but UMI seems to have taken the lead in the quality/customer service department IMO.
