resetting fuel trims
Old 08-14-2011, 04:17 PM
1toofastlt1's Avatar
Default resetting fuel trims
Hey everyone. I just finished my 97 383 build and now I'm trying to tune it in. My fuel trims are way off. Bank 1 is -12 and bank 2 is 25. I had a exhaust leak before but now that its fixed I need to reset the fuel trims. How can I do this? I'm tuning with jet dst and logging with mx scan. Thanks
Old 08-14-2011, 04:22 PM
LSWHO's Avatar
Reset long term trims? Pull the battery, pull the PCM, reload the tune. All three will reset ltfts or ints or what have you.
Old 08-14-2011, 04:24 PM
Ok so I have to do all three or just one of the three?
LSWHO's Avatar
Split BLMs is a common problem with cammed cars. Also with aftermarket throttle bodies. Google split BLMs and read through the various fixes to see if one can help you. I have split BLMs, but they aren't that bad.
Old 08-14-2011, 04:25 PM
LSWHO's Avatar
Just one of the three. The first two just leave either one unplugged for a half hour. I assume you could also pull the PCM fuse for a half hour to reset the tune.
Old 08-14-2011, 04:27 PM
Ok I have a very small cam cc305 and a 58mm tb. Thanks.
Quick Reply: resetting fuel trims
