just wondering???
Old Aug 15, 2011 | 04:05 AM
2 quick's Avatar
Exclamation just wondering???
at what rpm should i launch on a m6 lt1 because i have no traction whats so ever! mods: intake, exhaust,elbow
Old Aug 15, 2011 | 05:15 AM
Rob94hawk's Avatar
Get drag radials then you can do a 5000rpm clutch dump.
Old Aug 15, 2011 | 06:00 AM
RamAir95TA's Avatar
Man, the advice on this forum has taken a turn for the worse.
Drag radials are a compromise between street tires and ET streets and in no way guarantee traction. Things like LCAs and relocation brackets, front shocks, subframe connectors, weight, etc., all have an impact on traction. You can't deduce the lack of traction to just the type of tire, not to mention assuming a high rpm clutch drop would yield the results the OP is looking for. Sure, if he hooks, great, but the life expectancy of his 10-bolt will be drastically stinted.
If you want to hook safely and reliably, go with a full slick behind a 12-bolt, 9" or S60. Until then you're going to have to experiment with your current setup since every car/driver varies.
Old Aug 15, 2011 | 07:21 AM
Rob94hawk's Avatar
I would hope he knew I was joking.
You on the other hand forgot to turn your sarcasm detector on
Old Aug 15, 2011 | 07:37 AM
RamAir95TA's Avatar
My apologies....give me a break. It's too early.
