How important is 1 7/8 headers
Old Aug 15, 2011 | 04:25 PM
shaq_2500's Avatar
Default How important is 1 7/8 headers
I was trying to see how important is 1 7/8 headers on a Lt1 396 engine as far as HP wise and do I really need them?
Old Aug 15, 2011 | 04:32 PM
gregrob's Avatar
Yes..
Old Aug 15, 2011 | 04:40 PM
ElkySS's Avatar
mind going into a little more depth with that answer?
Old Aug 15, 2011 | 04:53 PM
pillarpod's Avatar
i'd be putting them on
Old Aug 15, 2011 | 07:32 PM
defaultexistence's Avatar
A engine is a air pump ,more air in =more air out. you have a NA motor demanding more air to perform . restrict intake or exhaust and you hit a wall in it's potential to make more power . In-depth enough yet? If not try the search button.
Old Aug 15, 2011 | 07:52 PM
gregrob's Avatar
They will make more power than smaller primaries. Pretty simple
Old Aug 15, 2011 | 09:16 PM
pro94lt's Avatar
I went from 1 5/8 mid tubes to 1 7/8 long tubes on my setup. I have no dyno or track results to compare but you really can "feel" the difference in power or at least I can in my set up. The car sounds much healthier, seems to honestly breath better and is much louder. Do it.
Old Aug 15, 2011 | 09:29 PM
http://en.wikipedia.org/wiki/Facepalm
Old Aug 15, 2011 | 11:41 PM
ElkySS's Avatar
its not that simple, i assure u. if it doesnt fit the combo, u will lose alot of low end torque. im curious if stepped headers actually show a big enough improvement. i dont really see how considering they start as 1 3/4 anyway.
Old Aug 16, 2011 | 07:46 AM
quik95lt1's Avatar
need more info on the setup it self other than "its a 396" lol........more info please........CR? heads? intake? cam? Peak power rpm and peak torq rpm as of now? also converter size rear gear and weight?
on my setup a 1 7/8" helped me alot........but i also START making power at 6500.....
Old Aug 16, 2011 | 09:23 AM
shaq_2500's Avatar
My compression is 11:1 or a little higher cause I put impala head gasket on it. My heads are Dart pro 1 aluminum with 2.08/1.60 valves, my intake is ported by LE, also my cam is custom grind from LE which stop pulling around 6800 rpm, my gears r 4:10, 3000 stall
Old Aug 16, 2011 | 09:24 AM
quik95lt1's Avatar
they'll help you..........
Old Aug 21, 2011 | 09:46 PM
SWells's Avatar
Think of the combined area of the additional 1/8 all the way around the outside of the circle. I'm guessing it would add up to another sq. inch of additional size for the exhaust to flow, that's significant.
