iv got a few tuning questions
im curious what my knock settings should be at to eliminate false knock. as soon as i open my cutouts, my knock sensor goes nuts.
my extended spark table says i should be at 32 degrees advanced at wot. datalogger says its at 36 degrees. i cant find out where the other 4 degrees is comming from
ElkySS - go to your Max knock retard vs. RPM (in PE) table and make sure anything above 4K is set to 0. Then go to your Max KR vs. MAP (not in PE) and set all tables (MAP reading where you are picking up knock - from your log) to 0. Lastly, go to your Burst Knock Retard vs. Coolant Temp and change all cells from -40-68 deg to 0. That should cover you and I'd recc. getting a LT4 km to help out with that false knock. You know how to reach me so call me if you need any help or have any questions.
I'm just saying that there is some advance that no one have been able to find where it comes from. Those discussions have been around for years. Cut outs are for the track, your good with them closed and on the street so that would be my soloution. Or just limit what can be puledl. Max it out to like 2?
