Help!!
Old Aug 20, 2011 | 10:29 PM
Luke1996ta's Avatar
Default Help!!
I have been trying and trying and already broke one puller and I cannot get the balancer off my lt1 Anything helpful tips??
Old Aug 20, 2011 | 10:33 PM
bigj2717's Avatar
Most of the balancers come of really easy just remove the three bolts. If it doesn't come off by itself use a three arm puller and make sure you only grab the balancer and not the hub. You can also spray some penetrating lube where the hub and balancer meet
Old Aug 20, 2011 | 10:41 PM
Luke1996ta's Avatar
I already used a puller and it broke I have the three bolts off and the bolt that holds it on the crank
Old Aug 20, 2011 | 10:43 PM
bigj2717's Avatar
There are only three bolts that hold the balancer on. You do not need to remove the center bolt.
Old Aug 20, 2011 | 10:46 PM
Luke1996ta's Avatar
I have tried everything and no luck
Old Aug 20, 2011 | 11:14 PM
shbox's Avatar
To remove the pulley, try this.
To remove the hub, try this. Sounds like you trying to pull the hub without putting something in the bolt hole to push against.
