Errr, was this suppose to go back on?
Old Aug 26, 2011 | 11:21 AM
the_merv's Avatar
Veteran: Air Force
Originally Posted by 02v8ta
Originally Posted by LT1FirebirdSLP
Wow, totally appears to be a transmission crossmember. Ya might need it... just sayin'.
You think that's a Trans Cross Member?
Old Aug 26, 2011 | 11:56 AM
LT1FirebirdSLP's Avatar
Seriously?
Find a 93-97 Manual or Auto X-Member and look at it. Pretty similiar at quick glance. And after researching it more thoroughly, I found this very part sold with 93-97 Auto X-Members.
Don't be a troll.
Old Aug 26, 2011 | 01:30 PM
the_merv's Avatar
Veteran: Air Force
Lmao..you're a
If you researched it then what exactly is that part called?
I've only torn a few of these cars apart.. just sayin'..
Old Aug 26, 2011 | 01:44 PM
Transmission Tunnel Brace
Has 4 identical bolt holes to the Automatic Transmission X-Member for a 93-97 F-Body and Manual Transmission X-Member for that matter.
I'll work on getting you the part number, sir.
Old Aug 26, 2011 | 01:49 PM
boostedlt1's Avatar
it's not a transmission brace... did you not read every other ****** post on here??...
+1 on replacing it with a tunnel mounted torque arm. mine doesn't make enough noise to bother me. i made mine with poly bushings though
Old Aug 26, 2011 | 02:00 PM
g-load brace .... Transmission Tunnel Brace .... is the function of this particular piece of equipment not to keeep the Transmission/Driveshaft tunnel from collapsing/coming together? I looked quick at the picture (maybe a second or less). Flame me for it. jeeze.
Old Aug 26, 2011 | 02:15 PM
93Z2871805's Avatar
Veteran: Air Force
That piece of punched steel would not prevent the tunnel from moving in or collapsing, the tunnel itself actually has ridges in it that would function better to do that. I could only imagine GM installed it to stiffen the chassis in that area for hard cornering to increase torsional stability and reduce flexing. I'll give them an "A" for effort, but it's still just a piece of punched steel though. SFCs or a cage would work better.
Old Aug 26, 2011 | 03:01 PM
the_merv's Avatar
Veteran: Air Force
It's for neither if you really look at it..IMO the purpose of that piece is to keep the driveshaft up when a U-joint breaks. That piece of stamped metal with the way it's shaped isn't really that supportive if you look at it.
Old Aug 26, 2011 | 03:07 PM
the_merv's Avatar
Veteran: Air Force
Here's the one on my MCSS..
No real structural strengthening piece here.....it's a full-frame car..
Old Aug 26, 2011 | 03:16 PM
boostedlt1's Avatar
there was an entire page of people saying that it was just a tunnel brace and was not important to keep on the car. which was correct.
then you came on defending that it was a transmission brace.. (this brace is located BEHIND the transmission) and that he NEEDED it. which was completely incorrect.
just trying to keep things clear.
i would agree with the_merv, most likely the only thing it would REALLY be good for is catching the driveshaft if it breaks. i have a pile of these things laying around because they dont clear most aftermarket exhausts. i've never heard of anyone noticing a difference without it.
all for re-naming it the "driveshaft safety catcher brace" say I!
Old Aug 26, 2011 | 03:33 PM
Camaro350Z28's Avatar
I couldnt just say I it wanted 5 characters, damnit! woulda been easiest post in my life!
I!!
Old Aug 26, 2011 | 03:53 PM
  #32
camar0corey's Avatar
What are people using for driveshaft loops if they have 4" exhaust? Also its a Denny's Nitrous Ready driveshaft also, not sure how the size is on it.
Maybe information can come from this circus.
Old Aug 26, 2011 | 04:13 PM
  #33
WS Sick's Avatar
Its actually an engineered noise maker to let you know youre exhaust is sagging.
Old Aug 26, 2011 | 06:08 PM
  #34
^^^ so in your sig.... i take it your ws6 is made of all tunnel braces?
Old Aug 26, 2011 | 07:43 PM
  #35
Paul Bell's Avatar
That's MISTER MODERATOR
The GM parts catalog calls it:
Reinforcement, floor panel at tunnel panel (to underbody brackets)
While I think the idea of reinforcing the floorboard from one side to the other is a great idea, the GM implementation of it with that flimsy little panel was poor. If it was a real structural steel bar from the factory, everybody would think it was sorely needed.
I sure feel better having the aftermarket bar installed-along with three-point sub frame connectors. Everybody should do this:
Old Aug 26, 2011 | 08:22 PM
  #36
the_merv's Avatar
Veteran: Air Force
Pretty shiny parts..they stay that way till the first water puddle..lol..
I..
Yup..even the windows..***** solid.
Old Aug 26, 2011 | 08:36 PM
  #37
94ss06gxp's Avatar
Doesnt that like hold up your transmission.
Old Aug 26, 2011 | 08:58 PM
  #38
mcalus's Avatar
See how there are holes for a trans mount.... Do you see that on the original pic? Fail....
Go back to mifbody
Old Aug 26, 2011 | 09:02 PM
  #39
whytryz28's Avatar
No it holds the car body from hitting the ground.
Old Aug 26, 2011 | 09:04 PM
  #40
speed_demon24's Avatar
It does a fine job. Try and stretch the stock piece and get back to us.
