Errr, was this suppose to go back on?
Old Aug 26, 2011 | 09:07 PM
  #41
94ss06gxp's Avatar
Originally Posted by mcalus
See how there are holes for a trans mount.... Do you see that on the original pic? Fail....
Go back to mifbody
Originally Posted by whytryz28
No it holds the car body from hitting the ground.
so thats why the middle of my car sags cuz i didnt put mine back on either.
Old Aug 26, 2011 | 09:15 PM
  #42
02v8ta's Avatar
LOL yay one of my threads exploded into madness.
Paul Bell I like your suggestion.
And yea it wouldn't clear my y pipe so we said f it. Was hoping it wasn't important I say "I" too for the re naming of it!
Old Aug 26, 2011 | 09:41 PM
  #43
Paul Bell's Avatar
That's MISTER MODERATOR
As my car is (sadly) a daily driver, my high-tech tubular stuff looks like ***. Black tubing looks better covered in *** than red so black is what I have. It performs just the same regardless of color or level of *** on it.
Old Aug 27, 2011 | 12:06 AM
  #44
the_merv's Avatar
Got to love that good ole road grime..
Old Aug 27, 2011 | 10:46 AM
  #45
95BlkBird's Avatar
That looks exactly like the piece that I trashed when installed the cat back. Made a horrible rattle lol.
Old Aug 27, 2011 | 01:10 PM
  #46
leadfoot4's Avatar
Originally Posted by Paul Bell
....I think the tunnel brace should not only be retained, it should be upgraded to one of the much stronger ones on the aftermarket. GM would NOT have designed, made and installed one on every single F-body if they didn't think it was needed.
I used to have one of the Granatelli Motor Sports bars, which was very similar to the BMR brace you posted the picture of. I took it off after a few months, however, as I dragged it on a couple of speed bumps in the parking lot where I was working at the time, and didn't feel the compromised ground clearance was worth the hassle.
Secondly, the "brackets" that these braces bolt to, don't look all that sturdy anyway. However, if you're also installing a 3 point subframe connerctor set-up, that's another story.
Old Aug 28, 2011 | 05:39 AM
  #47
the_merv's Avatar
This is a pretty good point..I actually ripped my Tunnel Brace mounted Torque Arm off of the car loading it onto the Trailer..ripped them pieces steel right off of the body.
This was my re-enforcement..
