High idle
Old Aug 25, 2011 | 08:41 PM
FAD2BLK93's Avatar
Default High idle
Hey guys need a little help. After my car is up to temp and i try to restart the idle will go up to 1500 to 1700 and slowly come down. It doesn't do it alot but it is annoying waiting for it. So i took a can of carb cleaner cleaned the IAC hole and she runs alot smoother now. I thought it might be a slow IAC...resetting itself maybe, i replaced it 25k ago, any thoughts thanks.
Old Aug 25, 2011 | 09:11 PM
defaultexistence's Avatar
Iac or it's wiring might be bad
Old Aug 26, 2011 | 08:37 AM
LT1FirebirdSLP's Avatar
Vacuum leak. Check intake gasket, TB gasket, PCV lines, Brake Booster lines. If you rev the motor to like 1500-2000 does it hang and take forever to come down? If so, then almost certain you have a vacuum leak.
Old Aug 26, 2011 | 07:18 PM
FAD2BLK93's Avatar
I did push the rear intake gasket at the last race shifting at 6000 rpm...got an oil leak now. Thanks
Old Aug 26, 2011 | 10:16 PM
96TransAmboosted's Avatar
You should probably say that when your trying to figure out a high idle issue. Could be IAC, vac leak or loose intake elbow after the MAF.
