Got a bone to pic!!!!
Old Aug 30, 2011 | 01:55 PM
madhatter's Avatar
Originally Posted by RamAir95TA
I don't have this problem with my WS6 airbox...
Hahaha
To the OP: I had the same issues. I ended up using three self tapping screws in it to hold it in place.
Old Aug 30, 2011 | 02:00 PM
ZGOBYBY's Avatar
You are talking about the K&N FIPK kit, right (non-ram air SS/WS6 car)?
Old Aug 30, 2011 | 02:03 PM
MuscleCarNut711's Avatar
95 here, never had that issue.
Old Aug 30, 2011 | 02:09 PM
BlackScreaminMachine's Avatar
Internet Mechanic
Originally Posted by jrplz
I have a 1996 camaro does anyone have the same problems with knn air intake (with the filter coming off) Ive gone through 2 filters all ready the come loose and bang around and get damage. Is it just me or does any one have this problem?
thanks
Jr
On my old 383 z28 I had a very similar issue as I tried to install the filter on the intake once it go through the small hole. Got sick of dealing with that so I cut the whole bigger and go the filter on very good. So basically when working on the car I had the set up to the point where I would disconnect a few sensors and the intake elbow to TB clamp and comes off as one unit.
Very useful when trying to work on the car often.
Old Aug 30, 2011 | 04:06 PM
94maro's Avatar
just take the filter off...its in a plastic box anyways just steer away from mudding ur car...lol
Old Aug 30, 2011 | 07:28 PM
Camaro350Z28's Avatar
never had that problem with a properly installed filter.
i have had problems getting the filter on at times but once its on (correctly) then clamped it does not come off
Old Aug 30, 2011 | 09:03 PM
jrplz's Avatar
this sounds good will try to do this thank you
Old Aug 30, 2011 | 09:05 PM
jrplz's Avatar
j/k
Old Aug 30, 2011 | 09:26 PM
R3DLT1's Avatar
Originally Posted by madhatter
Hahaha
That's one way of doing it! Lol
Old Aug 30, 2011 | 11:43 PM
MasterTomos's Avatar
I've been waiting for the day this happens to mine, seems like it could fall off easily. Still hasn't after three years tho.
Old Aug 31, 2011 | 08:06 AM
camar0corey's Avatar
Mine fell off years ago. Hasn't happened since though, takes some extra time but I make sure its over the tube now and use a 10mm socket to tighten the clamp instead of a screwdriver.
Old Aug 31, 2011 | 03:33 PM
  #32
derekstl's Avatar
I had the same problem in my 97. My motor mounts were worn out and the drivers side of the engine would raise up when you revved it so I think that pulled it off. I replaced the motor mounts and havent had a problem since. But the self tapping screw isnt a bad idea! I will keep that in mind if it happens again
Old Aug 31, 2011 | 03:38 PM
  #33
TCS OFF's Avatar
When i put a K&N cai on my 96 trans am it seemed like the filter wasnt very secure on the tubing, and it did indeed fall of but not when i was driving luckily. I just wrestled it back on there, doing a lot of excessive pushing and what not and then tightned the Sh*t outta the clamp. Hasn't come off again
Old Sep 3, 2011 | 11:26 PM
  #34
jrplz's Avatar
ok guys thanks for all the info ! I email KNN and had a long discussion with them. I posted this thread and they look at it and told me we should of came to them and told them about this problem that they never herd about this after that they sent me a new filter for my intake (hope this help you guys I was tired of buying filters at the tune of 39.00 **** that Pm me and Ill give you the contact person that helped me out with the filter
