95 z problems ..help please
Old Aug 30, 2011 | 12:26 PM
brixz's Avatar
Default 95 z problems ..help please
95 Z...Driving & car starting to loosing power, getting hot, low coolant
light came on & ses light came on & off. Found that the cat was clogged.
Gutted the cat & now the car has rough idle, low coolant light(level good)
getting hot, no fans & some power loss. Could this be O2 sensor or temp.
sensor that caused all of this? Any advise would be apreciated!
Old Aug 30, 2011 | 12:28 PM
RamAir95TA's Avatar
First have the SES codes pulled. That should give you a good starting point.
Old Aug 30, 2011 | 12:37 PM
brixz's Avatar
only problem is I live a ways out of town & don't have a scan tool & really not
sure if it can make it in town.Would you replace temp. sensor & O2 sensor first?
Don't think I can rent a scan tool. I'm open to any ideas,Thanks.
Old Aug 30, 2011 | 01:38 PM
LT1's Avatar
LT1
Almost sounds like a blown head gasket.
Check your thermostat might be stuck, might have multi issues going on at once.
Check the codes!
Dont throw parts on it untill you find out what the problems are. Fix it right first time, or youll go broke trying to fix it.
Old Aug 30, 2011 | 01:52 PM
Luke1996ta's Avatar
Sounds like HG to me mine did the same thing
Old Aug 30, 2011 | 02:36 PM
brixz's Avatar
Really?? wouldn't it be blowing white smoke if it was the head
gasket? Just asking... not doubting you. what kind of $ are we talking
about?
Old Aug 30, 2011 | 04:05 PM
defaultexistence's Avatar
GO GET A SCANNER! Post#2 is your answer for now otherwise your pissing in the wind
Old Aug 30, 2011 | 04:06 PM
And when does a head gasket make the fans not come on??!? Hell that could be why it's heating up
Old Aug 30, 2011 | 08:40 PM
mattj21's Avatar
Well if it was a hg check for leaks...no leaks..deffinately get it scan tool on it, go talk to a shop maybe they can have someone come to you..if they're nice enough that is.
Old Aug 31, 2011 | 09:31 AM
brixz's Avatar
checked last night no leaks, oil not milky.if I had to buy a scanner any ideas which
is good & reasonable & will it scan ls1's also? I did notice the liitle vacuum line w/blue
barb fitting is hanging down that was on the original air intake .not sure if that makes a
difference. Thanks
Old Sep 1, 2011 | 09:00 PM
LT1's Avatar
LT1
95 is the odd year which has OBD I or OBD II connector.
After you scan it, i would do radiator pressure test.
Old Sep 2, 2011 | 12:58 PM
brixz's Avatar
Ok..thanks.
