Noob questions
Old Aug 31, 2011 | 08:55 PM
95BlkBird's Avatar
Default Noob questions
There's a vacuum hose going from throttle body to passenger valve cover. Pcv valve correct? Can I cap it at throttle body and put a breather in pcv's place or does it need to be tuned out? Would clean the engine bay up some. Thanks guys
Old Aug 31, 2011 | 09:31 PM
95BlkBird's Avatar
So the pcv is on the intake itself. It's just a vacuum hose going to the throttle body then?
Old Aug 31, 2011 | 09:32 PM
96TransAmboosted's Avatar
That would be the fresh air tube. You can cap and run a filter if you want. I would also run a catch can on the pcv system.
