24x coil selection
Can anyone confirm if these are good coils for a 24x swap?
http://houston.craigslist.org/pts/3513807843.html
Says they are from a 2004 Suburban, but the pic is kinda grainy.
I run those same square truck coils with my swap. Only problem your going to run into is you need the coil harness which I don't see mentioned. If I were to do it all over again I'd buy the car ls2/3/7 coil packs as they are half the size. They aren't as cheap as the truck coils but I wanted my car up and running ASAP at the time.
