PCV on ASM Monoblade?
Old Sep 1, 2011 | 01:58 PM
Dave357LT1's Avatar
Default PCV on ASM Monoblade?
What are people doing with the pcv system on a ASM t/b? I was just going to run the filter on the valve cover but i have read that that could cause a vac leack and cause a rich condition. Could i run it into a catch can mounted on the firewall then return to the large vac port on the drivers side that isnt hooked to the break booster?
Old Sep 1, 2011 | 02:59 PM
DAVE00's Avatar
Are you talking about the fresh air hose on the pass vc? That is not the PCV system. The PCV runs from the bottom of the intake in the front to the driver side of the intake.
The fresh air can be deleted and if you choose a breather added.
Old Sep 1, 2011 | 03:22 PM
Dave357LT1's Avatar
O i thought that was part of the system to take blow by and put it back into the intake to burn it off..... I had the filter on there but was reading that it may pull in un metered air and cause it to run rich. If i can get away with the filter ill be happy i dont seem to have hardly any blowby with my new motor thank god.
Old Sep 1, 2011 | 03:35 PM
Badazz 97 TA's Avatar
The passenger side is the fresh air side. From what i understand it works in conjunction with the pcv. Im still trying to figure the whole PCV thing out and understand it
Old Sep 1, 2011 | 03:43 PM
Dave357LT1's Avatar
Now we are talking semantics but i think everyone knows what i mean.
Old Sep 1, 2011 | 08:37 PM
flyinZ's Avatar
Id just run a filter there, in the VC. I've had a Mono' on my car for a few yrs now, along with that filter..Never had a problem with it, or it ever causing me a rich condition.
Old Sep 2, 2011 | 07:10 AM
Dave357LT1's Avatar
Ok thanks
Old Sep 2, 2011 | 12:26 PM
Camaro350Z28's Avatar
keep the fresh air tube on the passenger side. it works with the PCV valve. they go together
Old Sep 2, 2011 | 01:40 PM
Dave357LT1's Avatar
It plugs into the throttle body. My mono blade does not have the port
Old Sep 2, 2011 | 03:51 PM
05HD's Avatar
The air going into the crankcase from the fresh air inlet is eventually injested by the intake tract via the PCV valve. This is why that air needs to be metered by the MAF sensor. The two best choices for a fresh air inlet, given your throttle body, would be to rig an alternate fresh air inlet somewhere else post MAF and pre-throttle blade or to have a tuner adjust the MAF tables to reflect the false air if you just really have to have that filter on the valve cover.
Old Sep 2, 2011 | 04:47 PM
oh oops i read it wrong i thought it said pcv or monoblade haha
