lt4 question
Old Mar 5, 2004 | 03:52 PM
Excal's Avatar
Default lt4 question
are these any different than lt1s in reliability? do they also have the "opti-spark"? is there a remedy so this will not be a problem?
i'm looking at this motor for a swap (thinking 240sx but can't get over how uncool most imports are and 3rd gen rx-7s are expensive) how is the aftermarket for these?
Old Mar 5, 2004 | 03:55 PM
Vendetta's Avatar
The LT4 is basically to the LT1 what the LS6 is to the LS1. Heads, cam, intake manifold are different. The LT4 is much more expensive, I think you'd be better off just purchasing an LT1 and stroking it up for your setup. If you decide on the 240SX, PM Aries, he has an LT1 240SX car.
Edit- Yes, they do use an Opti-spark, but it is vented. Vented optis have much less problems than non-vented.
Old Mar 5, 2004 | 05:44 PM
Excal's Avatar
I see, how does his car run?
this car might end up being my daily driver would yo uneed custom parts to make the swap work?
Old Mar 5, 2004 | 06:47 PM
Vendetta's Avatar
He's currently got the motor out and building a 396 to go in. As far as mods to make it fit, that I don't know, you'd have to ask him.
