Starting 383 Build...Input?
Stock LT1 Block bored .060
Callies Compstar 4340 Forged 383 Crankshaft
Callies Compstar H-Beam 6.000" Connecting Rods
Forged -5cc Pistons (what brand is recommended?)
ACL Race Bearings
ARP2000 Rod Bolts
A.I. 215cc TrickFlow 23* Heads
A.I. Custom Grind Camshaft
I will also be sending my stock Intake Manifold in to A.I. before I order my heads to have it opened up and matched to the A.I. heads.
I also would like to know what piston rings would be the best for this application? I plan on running a 150 to a 200 shot soon as well.
Current mods that will not be changing are: LS1 Style Air Intake System, 58mm Throttle Body, LPP Headers and Comp Cams Ultra Pro Magnum 1.6 NSA Roller Rockers.
Last thing I need to know...I currently have Ford SVO 30# Injectors, LS7 Lifters and Stock Oil Pump...do I need to upgrade and if so what do you suggest?
My goal is not necessarily to maximize the 383 Stroker, but I would like to get 75% of what it is capable of if possible! I appreciate the help!
The ACL stuff is nice, but also probably overkill. I like the Clevite H-series bearings. They have a lengthy reliability record.
There are a ton of good piston manufacturers to consider. If I were going to do my 383 build over again I would have invested in a nice set of Diamonds, but the SRP pistons I have now work just fine also.
Those 30# injectors will not be enough N/A so plan on some bigger ones for sure. Your nitrous setup will also be a big factor on injector selection.
The stock oil pump and the LS7s will be fine, but I would upgrade to the Melling 10554. It has a more robust casting and includes a hardened drive shaft. Also consider a larger aftermarket oil pan like the popular Moroso or Canton 242T.
I will definitely look into the diamonds and the clevites, thanks!
I will be running both na and sprayed at the track but this car is also a cruiser and weekend driver. I will have an OBD1 pcm and both an NA tune and a nitrous tune on t that I can load at any time at the track from my laptop, so what objectors would be ideal?
Do I have to modify anything to install one of those oil pans or no?
The cam does not have specs yet...I am just now starting to plan this. I will have it speced to the new heads/bore/intake.
And is suppose I shouldn't mention the fact that I found a 96/97 timing cover for $20 out here then...
