Happy Hooker Writeup?
PS: If you are going to post in here just to tell me to take it out the bottom you can just go ahead and click the back button. Thanks
AChotrod has it installed backwards on his motor, the curve of the hooker goes to the front so that you can clear the cowl once it is in...
I have done at least 2 dozen swaps with the Happy Hooker over the years... Great tool...
http://www.tpis.com/parts/view/67
1st. I had to drill a new hole in the boom of my engine hoist. Measured the difference between each hole which are 1000lbs difference. Cut that measurement in half and drilled the hole just past the 1000lbs hole to be about 500lbs. This will help clear the front nose without messing up the paint.
After that I pulled that engine by removing the radiator, and all Acc's on the engine. you can leave the opti and the hub but may or may not have to remove the water pump and damper. This all depends on weather or not you have you A/C lines still connected to the condenser. I don't have A/C right now so it much easier to turn the engine in the engine bay to make things clear.
I also remove the engine mounts completely.
You have to decide if you want to disconnect the trans and just put a trans jack under it or remove it completely. A 4 wheel trans jack strapped to the trans while holding the trans up and leaving the torque arm still connected will make sure the trans wont try to come with the engine. I keep all 4 wheels on the ground and the hood stays on. If you remove the hood you will have an easier time getting it out with A/C lines still connected in the car.
Here is a pick of what it looks like. I wish I had stopped and taken some in between but it went so well it was done before I had a chance.
The reason I want it to come out the top is because the car will still have to roll after the motor is out. I am not instantly putting one back in and the car is going to get moved for storage for the winter. I would rather pull the engine once and put it in once. Not drop the k member, put it back in, roll to winter storage, pull out of storage, drop k member, put it back in. Just seems stupid to do it twice.
