No Start
Old Sep 12, 2011 | 07:00 PM
LT-1 SS's Avatar
Default No Start
I have a 96 ss a4 pcm tuned by pcm4less. The car cranks with no injector pulse until the battery gets low then it will pulse and fire for a second or two. i called and verified that the vats is tuned off. Is there something i am missing? What could be causing this? maf is new and i have 48lbs of fuel pressure. I have checked all fuses and all that basic stuff. Any help will be greatly appriciated.
Old Sep 12, 2011 | 07:16 PM
Big Al's Avatar
No injector pulse. Do you have spark? Did you scan for codes?
Al 95 Z28
Old Sep 12, 2011 | 07:29 PM
LT-1 SS's Avatar
yes i have spark the only code is crank sensor that shouldnt hinder a 96
Old Oct 10, 2011 | 11:42 AM
LT-1 SS's Avatar
the driver ended up being bad on the computer, i replace that and it started for about 10minutes now it just starts for about 15 seconds and dies then will just crank until you turn it off and let it set for a few minutes then the same thing. any ideas on this.
Old Oct 10, 2011 | 08:39 PM
popethe5th's Avatar
sounds like your pcm is effed, thanks mail order tunes, cant really blame them lt1 pcms are becoming relics do 24X conversion i swear by it!
Old Oct 10, 2011 | 08:41 PM
popethe5th's Avatar
also see whats dying if your losing pulse from the pcm again it may be an injector pulling a ton of amps which ultimately caused the failure of the orginal pcm. or plugging in the PCM with the key on will fry the PCM occasionally
