dirty maf
Old Sep 12, 2011 | 07:56 PM
ByProxy's Avatar
Default dirty maf
can a dirty maf cause KR? i have owned my car for 3 years with a K&n and never cleaned my maf. i'm getting a lot of kr around the torque peak and the car isn't as fast as i think it should be. i took the maf off and looked at it and it has a bit of build up on it but i can't really see the intake side with the screen in the way. does this sound like it could be a major issue for me? I'm really wanting to be back to where I should be. Maybe it's causing my bad mpgs too?
Old Sep 12, 2011 | 08:11 PM
grazi's Avatar
If you run the car with the MAF unplugged and it runs better it is prob that. I had the same problem
Old Sep 13, 2011 | 12:00 PM
ahritchie's Avatar
Why not clean it and find out? Sounds like you diagnosed the problem already...either it's dirty or needs replaced. It only cost $5 to get some MAF cleaner. http://www.amazon.com/CRC-05110-Mass.../dp/B000J19XSA
Old Sep 13, 2011 | 12:24 PM
pancho toco loco's Avatar
^^^ what he said. Over time the oils from your filter can dirty up your sensor and cause false or improper readings. It's simple to do and not much of time or money to do
Old Sep 13, 2011 | 05:12 PM
LSWHO's Avatar
Just cleaned mine. My god was it dirty! Wanted to get before and after readings, but I got too lazy.
Old Sep 13, 2011 | 05:54 PM
ryanzcastro's Avatar
its easy to clean, just get some Maf or electronic cleaner spray
Old Sep 14, 2011 | 11:12 PM
Formula413's Avatar
Good preventative maintenance to clean it, especially if you have a K&N or other oiled filter. You can take the housing apart so you can get at the leads themselves without the screen in the way. Just be very careful with the sensor, it's delicate and expensive. And use the MAF specific cleaner, not carb or brake cleaner.
