weight reduction... my thread.
Old Sep 15, 2011 | 04:41 PM
  #41
alexcoreas's Avatar
I will be using all of the suggestions tomorrow and will post pictures of the rest of the **** I take out....
Just so everyone is clear I wasn't born on the track ... I'm the first generation and hopefully not the last ... this car is my project it was bought with the intent to fix and do the **** you guys do try to make it out to the shootouts... I am in college so doing the free stuff helps BC its free...
Oh yea this isn't a are you going to the ******* track thread so don't bring that **** up again... I'd rather you say shave my *** hairs or something that has to do with weight...
Old Sep 15, 2011 | 05:22 PM
  #42
93Z2871805's Avatar
Veteran: Air Force
Originally Posted by 402GOAT
here is a link to a members car i seen this morning. it been lightened a lot. there are links on his page to his build threads
https://ls1tech.com/forums/vehicle-c...ed-trades.html
That's insane!
That's the second person I've seen do something like that with the front end.
Old Sep 15, 2011 | 05:38 PM
  #43
alexcoreas's Avatar
I wonder how much time and money that cost....
Old Sep 15, 2011 | 05:50 PM
  #44
93Z2871805's Avatar
Veteran: Air Force
I don't know (I'm not too sure I want to either), but I do think the nose modification he did could be replicated rather inexpensively (providing either you or a friend can do the fabrication). I think you could do a version of that (a little heavier though) with thin walled small diameter mild steel tubing to make it easier to fabricate and cheaper.
Old Sep 15, 2011 | 05:53 PM
  #45
Dave357LT1's Avatar
shave ur *** hairs .
So ur not street racing or going to the track till you have a rear?
Lol so you just like driving around in a tin can for fun? You could have did that when you were "track ready" .
You could cut weight like a fighter before you do whatever it is you want to do with this car. Thats a good 40lbs after the sauna. Ill have some gatoraid wating for you in the Pits
Old Sep 15, 2011 | 06:27 PM
  #46
Spartan7's Avatar
Like this:
Nah, just kidding. Just a mid-project picture. But yea, that black plastic firewall padding is pretty heavy. Pass. airbag and all the HVAC is also more weight than you think (not sure if you already pulled that stuff).
I personally hate the gutted look, at least some lightweight carpet looks better than bare floors. But good luck to you.
Old Sep 15, 2011 | 06:35 PM
  #47
alexcoreas's Avatar
^^^^^ great point but I broke my entire dash so I just started the tearing ...I'm just saying I don't wanna hit the track and end up buying a new 10bolt when I could have saved it for a 9' ... I haven't changed my rear gear for that same reason I don't want to spend money twice.. I can honestly say I can't afford all the stuff you guys can I am in college, I have a house and a kid now so it's not that easy California is expensive ...
Old Sep 15, 2011 | 06:39 PM
  #48
alexcoreas's Avatar
Spartan your car looks naked... its sexy...
I plan on sanding it down and painting it.. my car looks ugly as **** with a chameleon interior and lime green exterior. I want to paint the inside Matt black... a light weight carpet is a great idea without the padding though...
Old Sep 15, 2011 | 06:40 PM
  #49
alexcoreas's Avatar
Is there an easy way to take off the arm rest in the back?
Old Sep 15, 2011 | 06:53 PM
  #50
Dave357LT1's Avatar
You can find good used ten bolts dirt cheap!! Go find one first then go tear some **** up.If it breaks then toss the extra one in. Im not changing my ten bolt till it breaks (I know it will) but dosnt wanna die!!! Have you changed the steering wheel?
Old Sep 15, 2011 | 07:12 PM
  #51
alexcoreas's Avatar
You still have the 10bolt? I will go to the track if it breaks then it breaks its not like I'm making power yet...
Old Sep 15, 2011 | 07:26 PM
  #52
Dave357LT1's Avatar
Yes sir!! Not sure how long it will last this winter. We shal see... I was cutting 1.7 60' last winter when it was just boltons and full weight. I wish i took out the weight i did when i still had my stock motor in to see the results. I just got kinda bored to fast. Not all ten bolts die easy. Some do.
Old Sep 15, 2011 | 07:30 PM
  #53
Dave357LT1's Avatar
Get some Ozite carpet. Its very light and looks 100% better than bare metal. the rear interior panels come out easy when needed so i put them back in to make it look normal. Door panels can go in or be taken out quick too. Ill only take that stuff out if i ran a 11.0.
Old Sep 22, 2011 | 02:28 PM
  #54
Whyrun's Avatar
Here's something to think about. By reducing the weight of the car, you are effectively reducing the stress on the 10bolt. I wouldn't be so quick to go hunting for a new rearend, I've beat my 10 bolt to death and its fine "A4". Plus a 9" ford is going to toss alot of weight back in your car.
Old Sep 22, 2011 | 04:15 PM
  #55
alexcoreas's Avatar
Yea that's very true and I have 3.23 in the rear off a 97 z28 I think that's the gear that came in an A4. Someone correct me if I'm wrong.
I will begin my weight reduction again tomorrow. Last week was hectic with homework ..
Old Sep 22, 2011 | 04:39 PM
  #56
Dave357LT1's Avatar
Thats what mine came with!
Old Sep 25, 2011 | 08:58 AM
  #57
89f150's Avatar
its not embarrassing to take your stock car there. i took my car and ran 14.5s all night and had a blast
Old Sep 25, 2011 | 12:19 PM
  #58
forgedlt4's Avatar
i run the stock carpet, minus the carpet padding.
Old Sep 25, 2011 | 01:15 PM
  #59
IronOutlaw's Avatar
This is 100% true. What is embarrasing however is going with a 400 horsepower car and running 13s because you cant drive and cant hook. I suggest going with the car stock to get used to racing.
Old Sep 25, 2011 | 02:13 PM
  #60
alexcoreas's Avatar
That's true... is there anything in particular I might need before I go to the track? Aside from 1/4gas in tank?
Closes track is irwindale 50miles away
