What is this thing?
Old Sep 15, 2011 | 08:45 PM
shix's Avatar
Default What is this thing?
what is the thing under the battery attached on the bottom of the passenger side frame horn?
Old Sep 15, 2011 | 08:50 PM
ZFreie's Avatar
Your coolant over flow container I think is what your talking about.
Old Sep 15, 2011 | 08:53 PM
shix's Avatar
no. its bolted on the bottom of the frame rail. has some kind of line running out of it. Not near the car right now otherwise id have a picture.
Old Sep 15, 2011 | 08:57 PM
SS RRR's Avatar
Village Troll
Possibly your vacuum canister.
http://shbox.com/1/4th_gen_tech2.html#HVAC_vacuum
This is a recent thread in here regarding A/C vents.
Old Sep 15, 2011 | 09:18 PM
shix's Avatar
yep thats it. the case on the outside i pretty well mangled on mine. Not sure how bad the damage to the rest is but im sure its bad. Had a chain wrapped around it when i pulled my motor. woops. can this cause any real problems other than my hvac system not working?
Old Sep 15, 2011 | 09:20 PM
Gojira94's Avatar
You are correct, sir...
Old Sep 15, 2011 | 10:21 PM
the_merv's Avatar
You can prob find a new one at a junkyard if you messed it up..or go oldschool and make it out of a soup can..
