Turbo on a stock LT1?
Old Mar 7, 2004 | 01:17 AM
66ImpalaLT1's Avatar
Default Turbo on a stock LT1?
Does anyone here have a single turbo on a stock LT1?
I'm considering turbocharging my LT1-powered Impala.
Old Mar 7, 2004 | 01:26 AM
Vendetta's Avatar
I wouldn't run more than 7-8 psi on unforged internals... where'd you get the LT1 from? Are you still running stock pistons/rods? Are you using a stock LT1 fuel pump? What size injectors?
Old Mar 7, 2004 | 02:07 AM
Thanks for your reply.
Its a 100% stock LT1 from my old '93 Formula that I wrecked, the engine has 45k miles.
Because its using a 93 ecu I'll change it to a standalone engine management system right away, and upgrade the injectors and fuel pump. Fuel lines -6 AN feed and return.
I'm really interested to know what turbo would be appropriate and what size crossover and downpipe are needed.
I'd also like to know how much power I can expect out of it.
Old Mar 7, 2004 | 02:39 PM
Vendetta's Avatar
With that kinda fuel you'll be able to run 5-6 psi pretty safely for a while, but you'll definitely eventually want to rebuild with some forged internals.
As far as the other turbo shtuff goes, I don't really know... you might want to try asking in the forced induction forum on camaroz28.com, there's lots of turbo LT1 set-ups over there.
Old Mar 7, 2004 | 03:54 PM
kevinb's Avatar
If the engine is out now i would go forged before you put it in, then you won't have to worry about it. Stock lt1's don't last very long with over 6 or so psi.
